Old 02-08-2008, 11:09   #1 (permalink)
Member: 301177
Thanks Meter: 91
1100 network problem
nokia 1100 no network found i change ant switch make jumphar,change the hager,and change the filters also but problem is not solve its all time showing no network found and some times its showing only one network "hutch' and at set is running with airtel sim any idea friend what can i do
thanks
Old 02-08-2008, 12:07   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
U only check the phone in hardware . . . .
before u check the phone in hardware u check the phone in software.
OK here is u r solution . . . Try and post result.
In software
1) u have write good PM file for network
2) After write PM file clear UI setting
3) And finnaly don't work this trick just heat the 3 small network switch (Below the antinna switch).
Post result.
Old 02-08-2008, 13:27   #3 (permalink)
Member: 228508
Thanks Meter: 55
change to cpuuuuuuuuuuuuuu
Old 02-08-2008, 13:35   #4 (permalink)
surajnad's Avatar
Member: 454011
Sonork: 1656095
Thanks Meter: 147
Chenge to PA 100% tested....
Old 02-08-2008, 13:41   #5 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Its UEM faulty try to replace
Old 02-08-2008, 13:47   #6 (permalink)
Member: 191089
Thanks Meter: 8
thanks ddddddddddddddddddddddddd
Old 02-08-2008, 16:11   #7 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
1100 netwirk {rebol the hagar ic}
Old 02-09-2008, 17:10   #8 (permalink)
Member: 301177
Thanks Meter: 91
here is any way to solve this network problem with out change uem becuse its very hard and new uem cost is too high
Old 02-10-2008, 08:01   #9 (permalink)
Member: 301177
Thanks Meter: 91
i wating for ans my friends
Old 02-11-2008, 16:39   #10 (permalink)
Member: 629694
Thanks Meter: 50
hi
hi sir just make jumper from hager to coupler and then to antina switch. tested ok
Old 02-12-2008, 14:08   #11 (permalink)
Member: 301177
Thanks Meter: 91
how i can make this please explan if any pic is possible
Old 02-12-2008, 14:27   #12 (permalink)
Member: 629694
Thanks Meter: 50
hi
i dnt have pic . bro their is a resistor near hager and if u wnt 900 then from right side first resistor to bottom last point of couler and then to middle point of ist line of coupler then to antina switch point .
Old 02-12-2008, 15:13   #13 (permalink)
Member: 301177
Thanks Meter: 91
bro can you upload any pic of 1100 and make the mark of this jumpher its very help full for me
Old 06-10-2008, 03:15   #14 (permalink)
Member: 497764
at first short or change antena switch and check
then short the pa if no net bar then short 3 filters with capacitor
if no net change IF ic
Old 06-10-2008, 03:22   #15 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
nokia 1100 network problem de brain box Nokia Hardware & Hardware Repair 9 03-05-2014 15:23
1100 network problem solved ..:MumbaiGsm:.. Nokia Hardware & Hardware Repair 14 02-07-2010 14:49
1100 network problem aberiya Nokia Digital Core Technology 4 ( DCT-4 ) 35 12-30-2009 09:14
1100 network problem satishyathi Nokia Hardware & Hardware Repair 1 06-16-2007 07:27
1100 network problem usman0000 Nokia Digital Core Technology 4 ( DCT-4 ) 22 05-29-2006 07:09
Page generated in 0.22830 seconds with 9 queries
