Old 12-20-2007, 21:39   #1 (permalink)
Member: 367928
Thanks Meter: 178
5200 keypaid ic change but still same
Sir 5200 come with keys problem 2,6,7 not working i reheat still same now i change four ic's but still same once i change one it work for a nigtht but in morning again some keys r not working i change one y one four ic (i use 6600 lcd ic) but some times some keys r working with othe ic some other r working now what to do NO water damage nor felldown
remembe i m using 6600 lcd ic
thanks in advance
Old 12-21-2007, 00:38   #2 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
6600 display IC is the same as 5200 Keypad IC. But are U sure ur IC is good? Try another IC. If not solved check Rap chip.
Old 12-21-2007, 03:38   #3 (permalink)
Member: 465901
Thanks Meter: 45
as you said sometime some keys are working sometime other are working after changing keypad ic. So your fault definately lies in the keypad ic and the 6600 lcd ic is the same as of the 5200 keyapad ic you can interchange them there is no doubt.As your post says , i think your fault must be in the keypad ic not in the RAp
Try with the brand new ic not with used ic, hope you will sucseed
Good Luck
Old 12-21-2007, 06:21   #4 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,697
brth replace the ic with new one and rember to use good paste to change ic [like orignal amteck flux volume 10cc]some time when we change ic it works for few hours but after few hours problem come again....this fult is also come through bad paste whic uyou use to change ic..... godd luck..
Old 12-21-2007, 12:19   #5 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
USE GOOD SKILL WITH GOOD EQUIPEMENTS, UR PROBLEM WILL BE SOLVE.ACCORDING TO U UR PROBLEM IS IN THE IC .JUST CONCENTRATE ON UR WORK
Old 12-21-2007, 13:21   #6 (permalink)
Member: 278058
Thanks Meter: 81
That is right! I had same problem in 6680 once. Key 4 was working each time I used even brand new IC's but came back. After reheating OMAP problem was solved. You try reheating RAP.
Old 12-21-2007, 20:56   #7 (permalink)
Member: 367928
Thanks Meter: 178
i m using brand new ic's but all four ic's r brand new
Old 12-22-2007, 13:11   #8 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Brand new ic may be faulti. Try original silver-packed ic or remove from a working board and reball it.
br
Old 12-22-2007, 15:45   #9 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
NOW I GIVE U A SIMPLE SUGGESTION TAKE OUT IC FROM WORKING SET LIKE NOKIA 6600,N70 .THEN MOUNT ON THE 5200 THEN U CAN CONFIRM IT HAS IC PROBLEM OR ITS PROCESSER PROBLEM.IF IT WORKS THEN MOUNT NEW IC TO REPAIR ON WHAT U ALREADY TAKE THE IC .IF U HAVE A GOOD SKILL THEN U CAN REPAIR BOTH SETS OTHERWISE INSTEAD OF ONE TAMPERED SET ,TWO SETS GOES DAMAGE.HOPE U WILL DO THIS..NOW I WILL WAIT FOR GOOD NEWS........
Old 12-23-2007, 07:50   #10 (permalink)
Member: 367928
Thanks Meter: 178
i change altleast six new ic's but now only 1 and 3 r not working as it work for some time then again it stop working and all keys r working with all ic's but after 10 to f15 menit 1 and 3 stop responding all other r working
Old 12-23-2007, 19:03   #11 (permalink)
Member: 367928
Thanks Meter: 178
whenever i change new ic all keys work but after 10/15 menit 1 and 3 stop responding all other r working perfectly
Old 12-23-2007, 19:08   #12 (permalink)
Member: 367928
Thanks Meter: 178
Old 12-24-2007, 21:14   #13 (permalink)
Member: 367928
Thanks Meter: 178
where is expertsssssssssssssssss?
Old 12-25-2007, 12:01   #14 (permalink)
Member: 559340
Thanks Meter: 16
check ur keybord treck
Old 12-26-2007, 10:19   #15 (permalink)
Member: 367928
Thanks Meter: 178
need keyboard wayssssss
second imei changed but still same ?? infinity team r u there ?? İ[email protected] Infinity-Box 2 07-17-2008 10:33
5200 Dead-flashing Ok-but Still In Dead zone2 HWK 6 06-30-2008 10:31
Formatted N95 Big But Still Same Problem shola5 MC-Tool 6 03-13-2008 10:02
L6 cemera hang then i flash but still same aukonline Smart-Clip 3 07-11-2007 21:18
V525 blue screen and turns off. flashed but still same crossings Motorola P2k 4 09-02-2004 09:36
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.27473 seconds with 8 queries
