08-29-2003, 09:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Czech Republic
Member: 3714 Status: Offline Thanks Meter: 6 | 5210 Charging OK, but cant TURN ON :( i have one 5210 with strange problem. when i put phone on a charger, it normally charges - lines goes up on the screen, but i cannt POWER ON the phone i can flash phone - so ON/OFF switch is ok and FLASH IC too... i tryed to reball cpu,cobba,hagar, but still the same anyone can help me? Thanx a lot Platy |
08-31-2003, 13:36 | #5 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | @Moosani @marple Quote:
09-02-2003, 14:00 | #9 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | @marple i don't think u want to tuch those boards.. for that price, just wasting your time... let put it this way.. i have replaced that V116 ( desolder from the good working phone) solder it on.. still don't work and the one (v116) from the dead board solder to the good phone and it working.. maybe better off offer Mr platy to repair his phone.. right??? |
09-03-2003, 22:21 | #11 (permalink) |
Freak Poster Join Date: May 2003
Member: 27721 Status: Offline Thanks Meter: 0 | you said you flashed your phone,but what did you flash only MCU and PPM or EPROM.I ask this because time ago i had same prob with 3330 and i had to flash PMM area,im not shure if 5210 has a PMM but try to flash full backup from working phone 200-600. Hope it can help Schiavo |
09-16-2003, 12:08 | #12 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | @ platy i got the solution will fix your phone man ,, i just discovered and tested works 100% ,..whoever say to change V116 isn't right solution, just mail me. [email protected] Regards TMPC |
09-18-2003, 05:17 | #14 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | hi platy, then i am not sure, cos this solution is working for 8210, i fixed all my 5 boards.. if the phone have voltage across the on/off switch and flashed ok and charging ok (battery bar running) so diffenately that solution i sent to u.. just check around R118, V360 see if any voltage go thru.. good luck |
11-26-2004, 11:52 | #15 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Spinning on my OWN Orbit
Member: 5358 Status: Offline Thanks Meter: 211 | hey I have also a trouble like that I change the flash cause its bad. i flashed it but if I turn it on it doesnt on. I flashe it again it is flashing. I turn it on but it cannot be turn on. what is the problen of this anybody can help me? |
P900 Charge Ok But Cant Power Up | shahjee | Sony Ericsson Hardware Repair | 0 | 09-30-2006 08:03 |
6100 Flash Ok but cannot turn on | NuengEve | Nokia Hardware & Hardware Repair | 7 | 08-17-2005 07:42 |
A50 charging OK! but cant power on | gama_cell99 | Siemens Hardware Repair Area | 15 | 04-03-2005 19:11 |
T68i beeps but cant turn on,chraging fine | hulala.[uk] | Sony Ericsson | 4 | 09-11-2003 20:40 |
