Old 09-10-2009, 08:21   #1 (permalink)
Member: 1048690
Sonork: aaj
Thanks Meter: 5
n73 problem
ihave a n73 with battery drinking problam for example if i listen to music for 10 minute it turn off please help me
tanks
Old 09-10-2009, 08:51   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
bro.use orginal battry.............
If not ok....
Change betty ic.............
Old 09-10-2009, 08:57   #3 (permalink)
Member: 1048690
Sonork: aaj
Thanks Meter: 5
during call it also have this problem
do u think it also is betty fualt?
Old 09-10-2009, 09:06   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro. i m allrady say 2 solution...
1st not work try 2nd....
1st chack battry
2nd.change betty ic........
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 09-10-2009, 14:51   #5 (permalink)
Member: 1048690
Sonork: aaj
Thanks Meter: 5
mr ashad420 i did it but problem not solved do u have any idea
Old 09-10-2009, 15:12   #6 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.now try it..............
result post here..........
Old 09-10-2009, 15:22   #7 (permalink)
Member: 1048690
Sonork: aaj
Thanks Meter: 5
tanksssssssssssssssssssssssssssssssssssss i will try
Old 09-10-2009, 15:46   #8 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,338
check ur imei then post result
Old 09-18-2009, 08:32   #9 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
tanks
brother if set without using not off then u need to check imei becose this is rpl problum
N73 problem usernome MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 03-30-2010 07:21
nsu and n73 problem waleedy Nokia Base Band 5 ( BB-5 ) 2 11-09-2006 20:37
my n73 problem??? Stylo_GSM Nokia Base Band 5 ( BB-5 ) 11 10-15-2006 23:14
N73 problem Flashing droesid MT-BOX 4 10-13-2006 19:32
Page generated in 0.17399 seconds with 9 queries
