Old 01-10-2008, 08:25   #1 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
5300how to remove securty code
i use user code edit &i use service i read code FAILED!!!
Can't read user code! or Code is default 12345 i use bb5 urgent help me
Old 01-10-2008, 08:37   #2 (permalink)
hackerbd's Avatar
Member: 247758
Sonork: 100.1574842
Thanks Meter: 259
Use search button.Any way check your cable.
Old 01-10-2008, 08:40   #3 (permalink)
SMDSAFE's Avatar
Member: 311990
Thanks Meter: 146
5300
FRIEND IAM 1000% SURE YOUR CABLE IS NOT GOOD.PLESE CHECK IT.
Old 01-10-2008, 08:46   #4 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
i check 2 cable same problem.......................................... i doing method is ok or bad
Old 03-12-2008, 18:11   #5 (permalink)
Member: 199538
Thanks Meter: 54
I was the same problem
I make the next procedure :
use JAF and try to flash with a higher flash in dead USB MODE ....
after that you can set the full factory default with FBUS mode normal
Old 03-12-2008, 18:43   #6 (permalink)
musmankhurshi's Avatar
Member: 166223
Sonork: 100.1587956
Thanks Meter: 36
dear very easy way
you unlock any bb5 with out fbus cable you need only
use usb cable or power supply you connect set with supply then on set or
connect usb cable set go too test mode & local mode
& you can unlock user code factory default life time
very easy way
to any bb5 user code
tested by me
m usman khurshid
0092300420120
How to remove securti code samsung w420 rinku24 SWIFT Platform 1 09-21-2009 19:15
seking can remove securty code for z310i uburo22 Seking Server 1 05-20-2009 16:44
please how to reove securty code in HTC herm300 seddik-gsm HTC & PDA WM( With Touchscreen) 2 01-03-2009 16:44
how to read securty code guddu206900 Universalbox 5 09-27-2008 07:59
V300 no ring, no any sound, after I remove securty code CezaricaGSM Smart-Clip 2 07-06-2004 09:54
Page generated in 0.20578 seconds with 9 queries
