03-27-2006, 20:43 | #1 (permalink) |
Member deceased !! Join Date: Jan 2006 Location: INDIA Age: 40
Member: 226535 Status: Offline Thanks Meter: 7 | Nokia 6260 Memory Card Corrupted If Possible Please Put A Diagram Which Indicates The Ic That Has To Be Replaced. |
03-28-2006, 18:32 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | change memory card ic or shor it [email protected] |
06-22-2006, 19:11 | #8 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | If memory corrupt that means there's something wrong about voltage, but if insert memory card that means something wrong about ways. Voltage in 6260 directly controlled by UEMK and ways could be affected by EMI filter. But the problem is the components regarding MMC and SIM Card is under the connector and the connector removing is really pain in the ***. Today i had a 6260 with MMC corrupt, when i compared with a good 6260 it seems that the damaged one had larger resistance than a good one. I believed this is caused by UEMK or C (capacitance). Does anyone had solution for this particular problem? Care to share? br, s1emens |
06-23-2006, 11:42 | #10 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 51
Member: 78767 Status: Offline Sonork: 100.95137 Thanks Meter: 566 | Quote:
again you made a mistake your given picture is not for 6260 its for other model (6600) we can not find R472 for MMC card please check ten time before posting don’t misguide forum members | |
06-23-2006, 11:44 | #11 (permalink) | |
06-23-2006, 18:47 | #12 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | @rajiv007 is there anyway to trick the switch so that we don't need the switch again. When this switch is damaged does it make mmc un-readable or mmc corrupt problem? br, s1emens |
06-24-2006, 18:06 | #13 (permalink) | |
05-05-2009, 18:35 | #14 (permalink) |
Junior Member Join Date: Dec 2008
Member: 919269 Status: Offline Sonork: sahaaaa Thanks Meter: 0 | n80 memory problem i had tried everything and putten memery card in card slot.but it tells .....plz insert memery card.even memery card inserted.........that too card is working.....i showen in shope they told to replace memery ic.is it true.replacing memory ic.will clear it.plz reply me |
nokia 6630 memory card corrupt | gbada | Nokia Hardware & Hardware Repair | 3 | 10-22-2010 09:32 |
nokia n81 memory card corrupted | royal_electronics | Nokia Base Band 5 ( BB-5 ) | 3 | 04-27-2009 08:51 |
NOKIA 6500s MEMORY CARD CORRUPTED | GELANEROB | Nokia Base Band 5 ( BB-5 ) | 0 | 09-02-2008 04:45 |
Nokia 3110c Memory Card Corrupted | inaam143 | Nokia Hardware & Hardware Repair | 3 | 06-03-2008 09:33 |
nokia 3230 memory card corrupt | obioha | MT-BOX | 5 | 10-11-2007 09:55 |
