Old 01-29-2009, 17:01   #1 (permalink)
tcdxb's Avatar
Member: 314698
Thanks Meter: 47
5310 damage IMEI
I have 5310 mobile but no display.i try to back up the crt it will done but the IMEI is 123456.... even i finish flashing this still failed in the end of flashing and still no power ..what is the procedure i can do to solve this problem.
Old 01-29-2009, 18:27   #2 (permalink)
khokonhajigonj's Avatar
Member: 771795
Sonork: 771795
Thanks Meter: 120
First flash with High version
Then if properly backup RPL write it in phone
Then do sx 4
Then write pm without 308
Do factory satting
If phone not back in right place
Put flash log and information
Old 01-29-2009, 19:21   #3 (permalink)
tcdxb's Avatar
Member: 314698
Thanks Meter: 47
I flash it to higher version and i try to put pm all is ok but when i try to connect to sx4 server it cannot connect is showing last cmd failed with error 0. when i writh rpl it showing can't decode rpl. i try to run all test the fail are st_camera_if_test, st_lcd_test, st_security_test, st_hookInt_test, st_cdsp_gsm_tx_power_test. and all are passed . the phone now is contact retailer.
Old 01-29-2009, 19:41   #4 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
U try now at any cost write pm by sx4. If write pm by sx4 contact retailer will solve
The Following User Says Thank You to khokonhajigonj For This Useful Post:
Old 01-29-2009, 20:04   #5 (permalink)
RD7
RD7's Avatar
Member: 444091
Thanks Meter: 21
I think get rpl will solve your problem.
The Following User Says Thank You to RD7 For This Useful Post:
5310 With Damage IMEI kasamiko MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-15-2010 18:22
:::::: REPAIR DAMAGED IMEI 12345xxxxx WITH RPL - HOW TO GET ORIGINAL IMEI HERE :::: GSMman187 Nokia Base Band 5 ( BB-5 ) 30 08-09-2009 06:58
How to repiar bb5 damaged IMEI if we missing orginal/Phone Back sticker imei ? ::.::RAMJAN::.:: Nokia Base Band 5 ( BB-5 ) 13 07-21-2009 07:29
T191 V1.87 Beps and Damaged Imei Johnessen Motorola ODM 0 01-17-2003 13:36
Page generated in 0.19249 seconds with 9 queries
