05-27-2004, 17:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: India (Mumbai) Age: 43
Member: 59915 Status: Offline Thanks Meter: 4 | jumper tricks?????? Is there any good jumper techniques for dead or network problems 3310,8210,8310 thanx |
The Following User Says Thank You to RAHUL12345 For This Useful Post: |
05-27-2004, 19:04 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Well Brother , totaly ' Jumper techniques ' in my openion is a bad " culture ". The best way for performing jumpers is to test , check , detect , and apply it , as U use the schematics and U do comprehende GSM hardware U'll do it as a peice of cacke. Regards |
05-28-2004, 16:41 | #8 (permalink) |
Member: 59915 Status: Offline Thanks Meter: 4 | i know this jumper trick is sometime temporary. but it is quick .As we find in charging problem in 3310.. pls post some jumping tips here if anyone here knows........ thanx |
05-30-2004, 07:30 | #9 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 71
Member: 58466 Status: Offline Thanks Meter: 19 | I 2 agree that is not a habbit 2 b followed.But most of the times watter logged sets tend 2 have a break in track like in 3310 there is always a cut in charging section,in which bridging is the only solution. |
The Following User Says Thank You to amal For This Useful Post: |
05-30-2004, 09:29 | #10 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | See Attached File Here Are Some Jumper Tricks For These Models, 3310,8210 And 6210. Have A Nice Day. Last edited by ahmedksal; 03-22-2008 at 15:36. |
The Following User Says Thank You to ahmedksal For This Useful Post: |
05-31-2004, 18:00 | #13 (permalink) |
Freak Poster Join Date: Oct 2003 Location: PL Age: 37
Member: 40756 Status: Offline Thanks Meter: 1,224 | For nokia 6610 is existing Jumper Trick solution ? Last edited by [c]Cinek; 05-31-2004 at 18:22. |
The Following 2 Users Say Thank You to [c]Cinek For This Useful Post: |
05-31-2004, 18:56 | #14 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | hay,, that bad ! you did not try to look real reason which part got problem , and you try to lazy work with short cut ? the way make "jumper" , it is if you do not have working antenna switch on hand, and you sure the antenna sw was "dead", then you can do it for TEST ONLY . i know it will work, but it total NOT GOOD ! you make phone only single band ! do not do that for your customer's phone ! |
05-31-2004, 23:31 | #15 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | ohhh Only Single band i do them in all Coz only 1 band working in my Country So it never makes any Prob at all for me !!! |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
N70 full jumper trick | dars_cell | Nokia Hardware & Hardware Repair | 21 | 08-16-2009 11:00 |
Jumper Tricks | Sniper_04 | Nokia Hardware & Hardware Repair | 7 | 12-11-2008 19:35 |
new jumper tricks | Andra | Universal GSM Software | 4 | 08-13-2008 22:47 |
X450 Switch - jumper tricks | pepik | Samsung Hardware Repair | 2 | 10-02-2006 06:55 |
Sony Jumper Tricks | gsmsikar | Sony | 2 | 08-23-2004 21:31 |
