02-15-2011, 13:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | 5800 powers off when making a call... this problem is similar to the 5530. Tried already to cover the small ribbon that is connected to the speaker. Tried also to remove the speaker to check if the problem is originating from it but still powers off. Last thing that comes in mind is a faulty PA but till now never read about such a source of a problem on the 5800. thanks for any help |
02-15-2011, 13:55 | #5 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | just checked now.... SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed |
02-15-2011, 15:40 | #9 (permalink) |
Freak Poster Join Date: Jan 2006 Location: philippines
Member: 216705 Status: Offline Thanks Meter: 48 | try to back up all rpl data see if there is an error ,else copy rpl ,then bus chech the go to advance and full erase then flash to higher version ,after finish write rpl and pm 1&309, post result |
02-15-2011, 15:49 | #10 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania
Member: 882067 Status: Offline Sonork: 100.1604678 Thanks Meter: 45 | well verify carefully the speacker ways , fot fine cuts because the metal shield of LCD press on board and short-cut the speaker ways to ground usualy with adesive band can solve this its a very common problem for 5130 , 5530,5230 |
The Following User Says Thank You to tzitzu For This Useful Post: |
02-15-2011, 18:05 | #12 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | I once had such a problem on E71 but when i cleaned the board with spirit,especially around the power switch,it stopped.I have also experienced such on 6303 and when i flahed it with latest firmware via usb on mxkey it worked perfectly.u may as well try these. |
02-15-2011, 19:04 | #15 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | yes problem is from the speaker cable. removed speaker and problem persisted. removed the cable and it was ok. I wonder how on earth this cable gets like this considering its not going any sort of strain like a moving one. thanks guys for the help. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Need help to make a site for free software | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-14-1999 22:57 |
For Jefferson -6110 goes off itself | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-19-1999 21:28 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
