5800d touch not working i replace with new touch but still the same i need help |
check its GND pins , upper center and low center pins are GND , consider Schematic or pic below never do copy paste , http://img227.imageshack.us/img227/7...ght5800gnd.jpg |
5800 touch keys not work I have also problem.but my touch working in exit side only(right bottom).i change touch and also touch connecter in pcb.problem still.touch four track resistance value are same in working pcb |
if touch is ok connecter is ok then heat the CPU carefully |
no neeed to heat CPU if touch ok touch conector ok final need to change touch control ic its same from 5530/5230/5800 |
brother try this No need to **** heat ,just reball or replace touch sensor ic its will solve ur problem 100% ,ic location is upper side of pcb |
