6020 keypad not work gree call key and red call reject key some time ok and some time not work i change the keypad ic but same |
if you change ic check clean pulsors or try replace with other ic should be damaged |
i change many ic after ic change mobile ok but after few minute same problem |
try change cpu....... |
change good keypad ic and clean keypad surface. |
Bro. ..resoldaring usb conector........ 2nd remove voliume key....... |
6020 keypad not work Cpu problem reball cpu or change cpu |
yes,,this is cpu problem,,,reball cpu,,hope its work |
cpu problem,rehot cpu or change cpu |
