Old 05-26-2007, 05:52   #1 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
6070 keypad not working
Actually it was insert sim ...i sloved the problem by jumper solution..
After that keypad is not working ....i replaced front board and keypad ic too..
but not worked ...
what to do???is keypad ic same as 6600????
help
Old 05-26-2007, 06:11   #2 (permalink)
Member: 513210
Thanks Meter: 110
Use keypad Ic came from 3220,or 8310.7210,7250 if you have...
Old 05-26-2007, 06:16   #3 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,822
plz check key pad ic
Old 05-26-2007, 07:34   #4 (permalink)
globaltelecom's Avatar
Member: 358717
Sonork: 100.1648649
Thanks Meter: 44
can some tell me about 6070 no buzzer & speaker help me far
Old 05-26-2007, 09:17   #5 (permalink)
Member: 350571
Thanks Meter: 920
but not worked ...
help
brother change keypad connector
The Following User Says Thank You to sree krishna For This Useful Post:
Old 05-28-2007, 05:34   #6 (permalink)
Member: 205738
Thanks Meter: 129
Thanks JOJO
problem is solved
Old 09-19-2007, 12:03   #7 (permalink)
Member: 333476
just reheat the upp with care ,100% ok if board is clean
Old 09-19-2007, 15:06   #8 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
Check the connector handsfree,replace Uem,replace Upp...good luck
Old 11-25-2007, 04:57   #9 (permalink)
Member: 221803
Thanks Meter: 18
please help 6070 insert sim i has reflow sim ic but still has insert sim pppppppppppppppppppppppppppppp
Old 11-28-2007, 18:52   #10 (permalink)
Member: 511560
Thanks Meter: 66
but not worked ...
help
try to reball upp or check board circuit, this kind of board easy break circuit, the keypad ic is same as 6600, 6630, n70, 6680, 6280 LCD ic
Old 11-28-2007, 18:59   #11 (permalink)
Member: 511560
Thanks Meter: 66
try to change a new sim ic, maybe can help you
Old 01-30-2008, 09:17   #12 (permalink)
Member: 308142
Thanks Meter: 20
Remove sim ic and try to make jumper all will fine gud luk
Old 01-30-2008, 15:09   #13 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
jumper is not a perfect solution try to replace the sim ic with new one .
Old 10-07-2008, 13:56   #14 (permalink)
Member: 511560
Thanks Meter: 66
yeah, jumper will make the sim card work without protection , sim ic just work like a fuse system wich is save sim card from abnormal voltage. I guess??
Old 12-21-2008, 15:34   #15 (permalink)
Member: 926660
plz i need help for the
kg195 auto off auto keypad buton working, keypad not working .by guljee guljee786 LG Hardware Repair 4 01-23-2011 18:41
k310i keypad not working and joy stick not working how can i make jumper shani72 Sony Ericsson Hardware Repair 1 12-09-2009 16:58
6070 3'6'9'# not working i chang keypad ic but same help me shani72 Nokia Hardware & Hardware Repair 2 08-14-2009 06:34
6070 mic not working mobile1repair Nokia Hardware & Hardware Repair 7 08-11-2008 07:13
2600c keypad not work up key,downkey,optionskey,cencelkey not work after change ic. lavkey Nokia Hardware & Hardware Repair 1 08-08-2008 16:52
Page generated in 0.20850 seconds with 9 queries
