10-31-2007, 09:40 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 533941 Status: Offline Thanks Meter: 0 | 6080/ 6070 --- keypad props , while calling too many sets are coming of this fault ,, while calling ,key number 8 or 6 is coming automatically , more friends are telling abt cpu , any other solution friends |
10-31-2007, 11:17 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | brthr first try to flash the phone with latest ver and good pm with jaf or mt box...... if not solve then change keypad ic no.z2400 ........ ur prob lem will defenatly solve good luck.... |
11-03-2007, 07:44 | #4 (permalink) |
Member: 533941 Status: Offline Thanks Meter: 0 | dear friend i tried both u mentioned above , any other solution friends ,, any way thanks for ur kind attention . i called to the customer care nokia they r telling that huge amount of these models are released by nokia having manufacturing defect they r taking back the all sets under 12 months nokia warranty in U A E |
11-03-2007, 08:59 | #5 (permalink) | |
Member: 522850 Status: Offline Thanks Meter: 0 | Quote:
Dear all New vertion is coming .Pls wait for some time....... King | |
11-14-2007, 08:52 | #6 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 46
Member: 116891 Status: Offline Thanks Meter: 15 | changing UPP or ESD Filter will solve the problem for short time and will come back again. also you can try to use the phone without tighten the screws u will not find a problem. but let us wait for the new SW maybe it will help !!!!!!!!!!!!!! |
11-16-2007, 11:07 | #7 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38888 Status: Offline Thanks Meter: 52 | Problem is solved 10X to russian bro. Problem is caused from missed connection between mainboard and keyboard grounds. In results parasites emitions caused prob. I solved it with wire between them, but it is a 4 places under keyboard to montage conductor rubber with suitable dimention. http://www.m*****-f****.ru/forum/sho...highlight=6080 |
11-25-2007, 22:58 | #9 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | I get same like prob but I will solve. 2 set is prob key bout connector. When you puss button. Bout connector gets shorts and another one is rehotting upp my problem is solved ...so check it.... |
11-26-2007, 06:35 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | Quote:
11-26-2007, 07:15 | #12 (permalink) |
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | |
11-27-2007, 16:47 | #14 (permalink) |
Member: 38888 Status: Offline Thanks Meter: 52 | By restore factory sometimes is impossible. Strange, but these phones are with the same first 6 IMEI digits. But as I told it is simple to repair. Simply connect two board grounds with wire (key board+main board) that is all |
11-27-2007, 18:39 | #15 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
BR Mansi | |
6080 no keypad light and display | bapd81 | Nokia Hardware & Hardware Repair | 2 | 03-05-2012 07:55 |
6020 6080 6070 6021 3220 not charging | faisalshah_2008 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 12-25-2009 10:47 |
6070 on hold during call | khanmobiles0003 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-14-2009 12:43 |
6080,6070 display no light | chandy pok | Nokia Hardware & Hardware Repair | 0 | 09-04-2007 16:41 |
c35 with any simcard inserted, shows "No Connection" while calling | sat | x1x to x45/x50 | 1 | 10-26-2001 22:34 |
