Old 10-08-2009, 12:33   #1 (permalink)
Member: 305843
Thanks Meter: 6
2330C RM 512 autoshut-off
hi,
does anyone here encounterd the auto shut off around 15 to 20sec.
history:
just send sms and it goes off suddenly then after powering on at around 15 to 20 sec it automatically shutdown.
action taken:
flash in 6.75 and version 8.20 still the same
gadget: jaf with latest ini
rehot upp flash ic and uem
nothing happen so anyone encountered a problem like this please share
tia
Old 10-09-2009, 12:06   #2 (permalink)
Member: 305843
Thanks Meter: 6
i'll just up this mates the unit still here thanks
Old 10-09-2009, 12:36   #3 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by dr_rule View Post
hi,
history:
action taken:
tia
change uem ...u can replace it from nokia 1200,1209,1650....
after changing uem write rpl through mx key and unlock it....''
ur problem solved 100 %.....
post result....
best regards,,,
digitized...
Old 12-09-2009, 15:49   #4 (permalink)
Demongsm's Avatar
Member: 168364
Thanks Meter: 174
hi,
history:
action taken:
tia
Hello Brothers!
Downgrade your phone to SW 06.46. then unlock again (it will be in Contact service) phone with MT. The other patch files for higher versions (6.75 and 8.20) tamper the SMS writing function with MT./Phone resets and white screen comes in entering write new message folder or restarts or switches off by itself/ /SW 6.75 won't turn on after patching!/
Select low level format before content-auto unlock after flash function for contact service and uncheck reset use code otherwise You'll loose more credits!
I have lost my 8 credits with this - Another bad movement MT TEAM! PLEASE FIX THIS BUG!!!
So mates - be careful!
So : 2330c RM-512 with MT can only be unlocked PROPERLY WITHOUT ERRORS with SW 6.46. on it.
Use only 2330_rm512_CareDP_5.0_06.46.exe
Best regards!
Hungary Forever!
"Energy is mass multiplied by speed of light square - Albert Einstein"
The Following User Says Thank You to Demongsm For This Useful Post:
Old 03-04-2010, 00:07   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
post result....
best regards,,,
digitized...
2330c uem is different from 1200,1208 and 1650
Old 03-04-2010, 05:46   #6 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
oh sory for that i have not trace the circuit at that time ....
ya nokia 1200 uem is differ from nokia 2330 uem ....if u want to get uem same as 2330 u can get it from nokia 2680,7100
@dr_rule
u can try this solution for 2330 auto shutdown......attached below....
The Following 11 Users Say Thank You to digitized For This Useful Post:
Old 03-07-2010, 14:19   #7 (permalink)
sharif_tell's Avatar
Member: 789364
Sonork: 100.1585484
Thanks Meter: 191
@dr_rule
thanks brother its 100% solution tested by me
The Following User Says Thank You to sharif_tell For This Useful Post:
Old 03-07-2010, 14:37   #8 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
hi,
history:
action taken:
tia
Bro.try this solution.
http://forum.gsmhosting.com/vbb/showthread.php?t=944138
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 03-07-2010, 14:42   #9 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
hi,
history:
action taken:
tia
check selftests in any box
then check radio test is passed or not
if radio test failled check or change bluetooth ic
if passed try to change or reball uem
tested by me
Old 03-09-2010, 15:51   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
radio and bluetooth test pass
i reball uem but still turn off
Old 03-09-2010, 21:00   #11 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
remove bsi resister then try
check charging time set auto off or not
Old 03-09-2010, 22:57   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i remove bsi resister but still same
but i didnt chk with charger anyway i will chk and reply
Old 03-10-2010, 00:39   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
yes it also turn off when charger is plug in
Old 03-10-2010, 13:04   #14 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
now wat to do mr wajid?
Old 03-10-2010, 14:38   #15 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
post your flash log here
The Following User Says Thank You to WAJID PNR For This Useful Post:
nokia 2330c RM-512 good pm kishalayabiswas Nokia Digital Core Technology 4 ( DCT-4 ) 4 09-10-2018 15:42
2330c RM-512 Pm parihar Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-08-2010 10:38
2330C Rm-512 auto off with Sim Tracer Gsm Universalbox 5 05-26-2010 17:17
2330c RM-512 auto off............ Dilip_Nath Nokia Digital Core Technology 4 ( DCT-4 ) 2 02-16-2010 19:05
2330C Rm-512 auto off with Sim Tracer Gsm HWK 4 01-04-2010 13:47
Page generated in 0.24275 seconds with 10 queries
