10-27-2008, 17:45 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: chattisgarh,India
Member: 578941 Status: Offline Thanks Meter: 108 | 6085 contact service with battery |
10-29-2008, 08:19 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | Quote:
contact service with battery any java based bb5 phone. 1-check battery connector's bsi pin, 2-resold/reball retu, 3-change retu. post reply. good luck | |
The Following User Says Thank You to shuaib_kashish For This Useful Post: |
10-29-2008, 08:57 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Age: 44
Member: 388207 Status: Offline Thanks Meter: 221 | hi Quote:
u have given such a solution which even a starter can give please be specific bro as to change retu is not such an easy tasking | |
05-17-2009, 05:58 | #11 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Bangladesh Age: 53
Member: 441231 Status: Offline Thanks Meter: 206 | Br. u r posted wrong subject. here is talking about 6085. anyway ur problem is not clear. write clearly. what happend in ur set. i mean all keypad not work? nor some work/ some not work? r u sure ur set's keypad ic ok? and how u sure the keypad ic ok? if not ok then change the keypad ic another set, not market ic.post result. B.R. |
06-27-2009, 12:22 | #12 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Heaven city
Member: 242387 Status: Offline Sonork: landri Thanks Meter: 36 | contact service 6085 dear sir!!! plz could u help me plz? i have nokia 6085. "contact service" this is the log ; owering the phone... Reading... MCU SW version: V 06.00 28-11-07 RM-198 (c) Nokia. HW version: 1402 PCI version: RFIC version: 17211721 DSP version: pb06w14v50.1 PPM version: V 06.00 28-11-07 RM-198 (c) Nokia. C Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 06.00 28-11-07 RM-198 (c) Nokia. Production serial number: PMD608758 Product code: 0550853 Module code: Basic production code: 0531924 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358630015167465 IMEI spare to net: 3A 85 36 00 51 61 47 06 IMEI SV to net: 33 85 36 00 51 61 47 26 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-198.ini Saved INI not found, loading INI list... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0550853 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ Searching for default location of ini... Checking path: \Products\RM-198\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! thnx u to aswer me. |
06-27-2009, 14:18 | #13 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | brother tell me press power button show contact service? or startup without sim press ok show contact service? |
05-14-2010, 13:11 | #15 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | I have also this problem. The phone is working on UFS normal mode. But with battery is not working. Can any one give me the BSI track of 6085 |
6610i contact service with battery help me | shivam4you | Nokia Hardware & Hardware Repair | 6 | 01-29-2009 14:49 |
nokia 6100 contact service with battery | bhogpurmail | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 06-08-2008 14:11 |
6610i contact service with battery | harshpahwa | Nokia Hardware & Hardware Repair | 6 | 05-23-2008 07:49 |
2310 contact service with battery ? | cellclinic | Nokia Hardware & Hardware Repair | 4 | 04-29-2008 11:57 |
