11-14-2008, 19:01 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 278693 Status: Offline Thanks Meter: 32 | Nokia 6600 disply probelm plz any pic solution. |
The Following User Says Thank You to frfaisal For This Useful Post: |
11-15-2008, 05:43 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, tell us details is your set call in/out ok? if ok then its your display fault try to change another lcd if your call in/out not ok , then try to format manually by pressing * + 3 + send button + power button post your result |
The Following User Says Thank You to jimm07ct For This Useful Post: |
11-15-2008, 05:51 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | Quote:
1-erase flash then reflash again.(you can use erase file) 2-write full pm and full reset. 3-format user area with any box. wbr shoeb | |
The Following User Says Thank You to shuaib_kashish For This Useful Post: |
11-15-2008, 21:31 | #7 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 6600 display Brother first u on it without sim card if show insert sim it means after sim set will b not boot so you flash it with cnt128 your problem will b solved if not its hardware prob first u change lcd if not change display ic |
The Following User Says Thank You to /\/\A/\/| For This Useful Post: |
Nokia 3230 white disply probelm | frfaisal | Nokia Hardware & Hardware Repair | 12 | 02-09-2011 22:30 |
nokia 6600 slide disply light | manikreddy444 | Nokia Hardware & Hardware Repair | 1 | 09-04-2009 21:32 |
