Old 08-13-2003, 17:59   #1 (permalink)
Member: 7586
Thanks Meter: 11
3210 buzzer problem
Hello to all.
i have 3210 with damaged buzzer pad + .
on 3210 there are 4 pads on PCB.
x -??? 0 - to UI pin 6
0-gnd 0 - gnd
where to connect this damaged?
b.r.
Pali
Old 08-13-2003, 19:33   #2 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
The buzzer circuit is so simple that you can fix it in few minutes!!
The + pin is connected to a hole near the LCD contacts:when you turn the board with the buzzer facing up there are 3 vertical holes just by the last LCD contact on the right.The + pin from the buzzer is connected to the MIDDLE HOLE near the LCD pins.
If you got me right and all other is good the problem is solved!!
I`m sorry that I don`t have a picture,but I hope this helped you.
Salut!!!!
Sony J70 buzzer problem Porter Sony Ericsson Hardware Repair 9 03-16-2005 11:36
3210 Buzzer .................... fdupoi Nokia Hardware & Hardware Repair 7 08-10-2003 07:54
R200 buzzer problem tereshuk Samsung Hardware Repair 1 05-27-2003 13:11
T 190 buzzer problem Moosani Motorola ODM 1 03-06-2003 16:21
3210 Buzzer Problem! aspog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-05-2001 17:06
Page generated in 0.18665 seconds with 9 queries
