10-13-2005, 19:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | 6101 Contents Package Extracting Failed I have NK 6101 water damage. Now it can connect with PC but can't Init Local Mode and Contents Package Extracting Failed: 1st Boot Ok, DCT4, UPP: 2142 Fl0: 0x01000000-0x01FFFFFF,00208826,St M28W128 Algorithm: u_st_i.fia Algorithm Ok, MSID: 8428CCB26DED488F686D799FF0 Decoded MSID: 9F7EBAE9-00550995-AA000000 Encoded FAID: B6C09AB4-2B224FC0-40B2E898 Area1: 0x01000000-0x0101FFFF Erased, Time: 00:01 Area2: 0x01020000-0x018BFFFF Erased, Time: 01:20 Area3: 0x01E60000-0x01FDFFFF Erased, Time: 00:13 MCU Flashing Completed, Time: 02:53 Area1: 0x01B20000-0x01E5FFFF Erased, Time: 00:30 CNT Flashing Completed, Time: 00:31 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile I have change UEM, Flash IC and UPP but nothing change. Can any1 help me about this solution? Thanks in advance. B.R Vinh Hai |
10-14-2005, 10:58 | #5 (permalink) | |
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
OK, I have changed UEM and Flash IC from another 6101 but nothing change. How to test the tracks under Flash IC? Can u help me? B.R | |
10-14-2005, 11:31 | #6 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | i have more than 10 phones like 3100 6100 and even on 6230 that all are dead and flashing stops at CNT file flashing. without Cnt file flashing completed but phone does not power on. I have changed the UEM but no luck. Any solution will be appricated. br |
10-14-2005, 11:45 | #7 (permalink) | |
For 3100 try to use FW version 5.09, sometime will be OK. B.R | |
10-15-2005, 02:41 | #9 (permalink) | |
This is 4rum!!!. Maybe u are No 1 man so u say that. I have checked lines connect between UPP and Flash. Have 3 lines broken. Now my phone working good. B.R Vinh Hai | |
10-15-2005, 03:02 | #11 (permalink) | |
What's version of FW u use to flash 3100?. Yesterday, I finished a 3100 (have same problem). I 'm using UFS_DCTx ver 1.3m, I have tried to down/upgrade FW of 3100 (from 3.10 to 6.01) but for this 3100 only version 5.09 the CNT can extracted and the phone working normaly. But sometime I must change UEM ic. I think u try to do this, may be helpful for u. B.R Vinh Hai | |
10-15-2005, 03:08 | #12 (permalink) |
Member: 6919 Status: Offline Thanks Meter: 12 | Uem already changed. i have used 5.54 and 6.11( thats two i have) since the phone came to me as dead dontknow the org ver. now trying to find the broken lines between upp and flash. br |
10-17-2005, 01:27 | #13 (permalink) |
Freak Poster Join Date: Aug 2002 Location: right here
Member: 14607 Status: Offline Thanks Meter: 10 | with Nokia 3100 & 6100 , when using UFSx/twister to flash them is no so great. sometimes you have to pwr-up the fone manually ( press pwr button when fone not booting ). try this hopefully may help you. br ktv |
6020 Contents Package Extracting Failed | ngaia | Nokia Hardware & Hardware Repair | 28 | 05-27-2018 14:21 |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 32 | 08-06-2010 07:49 |
6230 contents package extracting failed? | torbay | UFS2 + UFS3-Tornadoflasher | 6 | 05-15-2008 09:29 |
Contents Package Extracting Failed for 6020 and 3220 | singapore | Nokia Digital Core Technology 4 ( DCT-4 ) | 16 | 02-16-2007 18:39 |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 0 | 02-09-2004 16:31 |
