Old 01-05-2009, 15:38   #1 (permalink)
kcs_reddy's Avatar
Member: 918795
Thanks Meter: 135
Arrow 1200 menu---*---0--#--9 keys not working
my 1200 dropdown set menu---*---0--#--9 keys not working.... i'm also change keypad ic(protector) any bady help me please...............
The Following 2 Users Say Thank You to kcs_reddy For This Useful Post:
Old 01-05-2009, 15:45   #2 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
100% key ic problem change one more time ...
The Following User Says Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-05-2009, 15:45   #3 (permalink)
Member: 581178
Thanks Meter: 438
100% key ic problem change one more time ...properly..
Old 01-06-2009, 08:03   #4 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
Thanks Meter: 449
change keypad ic properly or
if ic not matched so take ic from other dead circuit......
Old 01-15-2009, 08:35   #5 (permalink)
tutu1982's Avatar
Member: 193430
Thanks Meter: 123
Dear Rumen sir i have same problem but i have only menu key problem i change key ic 3 times but every button work properly only menu button problem. what can i do si plz tell me.
Old 01-15-2009, 08:38   #6 (permalink)
Member: 513210
Thanks Meter: 110
if not work by changing keypad ic...
it may solved by reheating or reballs Or change Upp...
100% problem solved
Old 01-15-2009, 08:38   #7 (permalink)
Member: 21937
Thanks Meter: 279
try reheat upp if not glued
Old 01-15-2009, 08:39   #8 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
try make jumper... but its just for temporary..
if ok then juct change ic jumper...
The Following User Says Thank You to fasany For This Useful Post:
Old 01-15-2009, 08:50   #9 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
just rehot upp and rebol upp
The Following User Says Thank You to metro2mobile For This Useful Post:
k500I key 7,8,9,*,0,# and joystick not working rajput_jitendra Sony Ericsson 2 09-20-2008 20:40
nokia 2100 keys 0,#,9,6 not responding albert maren Sagem Hardware Repair Area 0 06-01-2006 13:08
3220 *,0,# clr, key not work Amit Tank Nokia Hardware & Hardware Repair 5 03-09-2006 14:37
3220 *,0,# clr, key not work Amit Tank Nokia Digital Core Technology 4 ( DCT-4 ) 0 02-08-2006 10:34
6600 *,#,c keys not working 47eleven-t Nokia Hardware & Hardware Repair 5 01-18-2005 17:29
Page generated in 0.19604 seconds with 9 queries
