Old 12-24-2003, 11:11   #1 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation Building Cables
Hi, i'm having problem in building the flasher cables in dejan scheme. i have 74hc14 but don't have diodes so i use external power supply 5 v from my front usb port. it doesn't work. i'm very desperate @ this moment!! can anyone help me on how to build the cable without using the diodes?? or using the IC 74ls14?? PLease do reply!!
Old 12-24-2003, 13:55   #2 (permalink)
Member deceased !!
Winner58's Avatar
Member: 5
Thanks Meter: 1,884
[GLOW=red]why you post outside the specific subforums???[/GLOW]
moved from Nokia DCT-3
Old 12-24-2003, 20:28   #3 (permalink)
Member: 39601
Thanks Meter: 13
The 1N4148 diodes are verey verey common ,they are the basic
universal levels of diods. U'll find them in any electronic PCB,toy,
calculator, clock , ect.
The IC 74Hc14 is a hex (6) "schmidt " inverters , U can replace it
with the 74HC04 ( the same ) but U'll lose the (schmidt) facility
wich is importatnt for the stabelity of the pulse streem interfaceing.
Old 12-25-2003, 20:45   #4 (permalink)
Member: 42161
Yes, the 1N4148 is the diode the most sold in the world !
Old 12-27-2003, 14:02   #5 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
building cables
It's me again, netdragon!! well thankyou 4 replying. i'll try 2 find the diodes in calculators or electronic PCB'S. well, as i mentioned i built the cable without the diodes. when i connected it with my 7110 i tried 2 read the phone with Rolis, it read and mentioned something like : MCU chk less and asked me 2 save the file it was only 4kb. i emulated communication with knok but said can't find ppm block and try overrule flash file. well you might say that why didn't i read the phone with knok?? bcoz when it's time 2 switch on the phone knok says cannot prepare phone on the other side, with rolis when it read a part of it @ the status it's written NSE-5 phone not accept flash read command AFTER HAVING SAVED THE 4KB flash file!! now my phone is saying : contact service. What do i do now?? do reply. by the way is 1N4148 included in data cables? & another question: will data cable flash if i uses a converter 25pin>9pin?? plz do reply i'm very desperate!!
Old 12-27-2003, 17:52   #6 (permalink)
Member: 42161
If you just want to unlock it, it's easier to use an M-BUS cable, because it uses only two wires, and the software (i use the old nokia tool buid 34) works fine with earlier models !!
it can also display security code for new models, and can perform full factory reset for some phones wich even don't accept the displayed security code !!
Old 01-01-2004, 23:46   #7 (permalink)
Member: 39245
Thanks Meter: 43
I've ever build that flasher and I complete it successfully. IN4148 diode was the very common diode.
So just build it as in the schematic!!!!!!!
Don't use the 25 to 9 pin converter cause flasher uses 25 pin (LPT port) that in 9pin (Com / RS232) has no that kind of pin in it. IF it is still no success.... buy it. It was very cheap.
BR,
Djo
Old 02-22-2004, 04:20   #8 (permalink)
Member: 54469
BR,
Djo
please help me build a flasher...
Old 02-28-2004, 13:06   #9 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation How to assemble cable?
hi,
I've got all the components required. i breadborded the components but flasher cable is not working... i need step-by-step detail on building the cable with graphics if possible. please help me. i badly need my phone.
regards,
|N|3t Dragon
Old 02-29-2004, 04:42   #10 (permalink)
Member: 54469
hi net dreagon?? u are from mauritius?? me too
please help me build my flasher cable as me too i badly need my phone, we could join hands for example...
Old 02-29-2004, 13:40   #11 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation so, u wanna build the cable?
assalamualaikum,
ki p dir la?? first u need to buy the required components:
- IC 74HC14
- CAPACITOR ELECTROLYTIC 100nf (OR 0.1uf)
- RESISTOR 4700 ohms
- 2 DIODES 1N4148
- A CONNECTOR PROM PARALLEL PORT(PRINTER PORT)
then u need to mount it accrding to the electronic scheme.
well, where do u live exactly?
u can sms me on +2304948192.
Old 02-29-2004, 22:41   #12 (permalink)
Member: 12207
Thanks Meter: 2
Hi! this is an easy one to build... I don't have pictures of it! U need only to worry, about capacitor polarity, the way you put the diodes in the cirtuit! in the capacitor, the negative pin (-) will go to ground. For the diodes, that | representes the black circle in the diode itself! i assume you know the chip pinout... oh, and another thing... you dont need to put all those signals in the mobile! for example, 3310 don't have Btemp.
Hope it helps...
Regards...
XARiUS
Old 03-01-2004, 02:35   #13 (permalink)
Member: 54469
walékoum salam,
korrec toi?? mari chance pou zoine ar toi ici!! moi, curepipe toi??
thanks a lot for helping me, i will start assembling it as from now
Old 03-01-2004, 15:53   #14 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation Assembling
just draw the circuit on paint and attach it. not the scheme but the picture.
Old 03-03-2004, 09:40   #15 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
post link where there is the picture of all mobiles pinout!!!!!
I need it.
I have build cable flash for sciphone i68+ dariodediablo Infinity-Box 3 09-19-2009 12:10
how to build cable to unlock my100x, new board without tp GOODNESS SAGEM JTAG UNLOCKER 2 06-08-2008 11:13
Help me pinout v10 build cable not ok halongmobile Infinity-Box 6 04-17-2006 22:12
How to build cable for NME-3 Mobilmicke UFS2 + UFS3-Tornadoflasher 0 07-19-2005 13:05
sharp gx10 result after build cable Chawkiz_gsm Sharp 6 04-18-2003 00:50
Page generated in 0.24137 seconds with 9 queries
