Old 01-12-2010, 14:13   #1 (permalink)
Member: 1050677
Thanks Meter: 12
6120c
6120c blue screen ??? any solution???
The Following User Says Thank You to mahianu For This Useful Post:
Old 01-12-2010, 14:48   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Change Lcd Or Flash Latest Version Or Change display Ic Near The Lcd Conector Or Resold Or Change Lcd Conector
Old 01-12-2010, 14:51   #3 (permalink)
Member: 1050677
Thanks Meter: 12
bro i change lcd, lcd ic, lcd conector but same complaint
Old 01-12-2010, 15:03   #4 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
then flash ur set maximum problem in lcd display ic or lcd conector try again change display ic corectly and check lcd conector again
Old 01-12-2010, 18:18   #5 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
brother first try by LCD , if same problem then change ur display IC , be sure that u r adjusting it correctly
Old 01-12-2010, 18:23   #6 (permalink)
Member: 445578
Thanks Meter: 440
call incoming & outgoing ok???
Old 01-13-2010, 06:09   #7 (permalink)
Member: 1050677
Thanks Meter: 12
bro set is not booting.
Old 01-13-2010, 06:17   #8 (permalink)
Member: 798117
Thanks Meter: 267
mate try to flash with usb cable
What is diference of Unlock Nokia 6120C Italy and 6120C Spania ??? Unlocker_001 BB5BOX 4 03-30-2008 11:53
6120c can not read by USB cable foony MT-BOX 4 07-18-2007 10:39
6120c Fbus flashing fail jodge MT-BOX 0 07-17-2007 13:40
Page generated in 0.15795 seconds with 9 queries
