Old 11-16-2008, 07:01   #1 (permalink)
Member: 550886
Thanks Meter: 69
nokia 6600 joy stick & 6 key not working
joy stick & 6 key not working my nokia 6600 i cheng key ped ic but not solution & cheng key ped belt but not rigalt
Old 11-16-2008, 08:33   #2 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Change both two ic & post result
By Shantobhai at 2008-11-15
The Following User Says Thank You to Shantobhai For This Useful Post:
Old 11-16-2008, 08:39   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
try to change keypad flex bro...
Old 11-16-2008, 08:47   #4 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
mate try it
IT
Old 11-16-2008, 08:47   #5 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
sir the unit is 6600...
Old 11-16-2008, 09:55   #6 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Sorry about this here is 6600 key pad ic ditail
By shantobhai at 2008-11-16
Old 11-16-2008, 09:57   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
dear brother this is not 7610,,,this 6600
Old 11-16-2008, 09:59   #8 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
good work dear brother,,,keep it up,,,
Old 11-16-2008, 10:01   #9 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
just try change flexi cable,,,,solved 100%
The Following User Says Thank You to gsmshare For This Useful Post:
Old 11-16-2008, 10:05   #10 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
or try this two solution
http://www.usaupload.net/d/hqlk3mkdymv
http://www.usaupload.net/d/5xmtfzms4rm
all the best,,,post result
regards
gsmshare
Old 11-16-2008, 16:10   #11 (permalink)
ira balisi's Avatar
Member: 316429
Thanks Meter: 80
try to reheat first the keypad ic, then resolder the keypad connector.
if no result, change the whole keypad and joystick...
i encounter this kind of problem before...
Old 11-16-2008, 16:24   #12 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
dear brother.
1.try to change inner keypad with joistic.
2.rehot or change keypad ic.
then post result.
Nokia 6600 Joy Stick Up key not working Saleemsmj Nokia Hardware & Hardware Repair 4 12-20-2009 13:31
Nokia 7610 Menu & Camera Key not working Saleemsmj Nokia Hardware & Hardware Repair 1 10-15-2009 10:37
nokia 5300 middle, up & down key not work nitish1 Nokia Base Band 5 ( BB-5 ) 4 06-23-2008 17:06
My 6600 Fell down, 789 & disconnect Key not working Jasninder Nokia Hardware & Hardware Repair 2 09-18-2004 14:27
nokia 6510 send & end key not work tanmay Nokia Hardware & Hardware Repair 7 02-13-2004 22:02
Page generated in 0.26341 seconds with 9 queries
