09-08-2009, 08:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | 6120c lighting problem solution pls??? pls give me images solution.......... |
09-09-2009, 00:18 | #3 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | Quote:
here u go mate....try this solution hope it will help u post result | |
The Following 2 Users Say Thank You to chohansahib For This Useful Post: |
09-09-2009, 04:40 | #4 (permalink) |
Major Poster Join Date: Nov 2008
Member: 909444 Status: Offline Thanks Meter: 25 | check out that 2pcs yelow component ,same as nk3310 change it will be done if no water damage.. i was done alot set b4..if change all same it then rehot area the light ic...if still same then finally change the batery ic.. and remember check the conecter...good luck=) |
NEED 6120c LIGHT/LED SOLUTION | joni_yang | Nokia Hardware & Hardware Repair | 15 | 01-21-2012 07:48 |
6120c light problem | ***GSM-LONI*** | Nokia Hardware & Hardware Repair | 44 | 11-06-2011 08:05 |
nokia 6120c light problem | m zubair | Nokia Hardware & Hardware Repair | 6 | 01-31-2010 14:05 |
6120c lights problem | dmad cellular | Nokia Hardware & Hardware Repair | 2 | 01-05-2010 14:28 |
6120c light problem | p.sekar | Nokia Hardware & Hardware Repair | 4 | 09-23-2008 16:32 |
