Old 12-24-2005, 00:32   #1 (permalink)
Member: 36741
Thanks Meter: 5
Unhappy 7610 white screen
HI ALL friends
I need experts idea i 've 7610 that was fall on floor by big shock then display went lcd connecter and pcb is ok but screen not show display also checked in other fone plz plz plz give any experimental idea
The Following 2 Users Say Thank You to nasir shiwani For This Useful Post:
Old 01-05-2006, 03:20   #2 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
your phone can make call or not???
The Following User Says Thank You to banalven1 For This Useful Post:
Old 01-08-2006, 23:47   #3 (permalink)
Member: 36741
Thanks Meter: 5
no sir phone can not dial and receive i thing it's condition is on <insert sim card> it,s my idea not sure
The Following User Says Thank You to nasir shiwani For This Useful Post:
Old 01-09-2006, 01:21   #4 (permalink)
Member: 44950
Thanks Meter: 10
if the phone can receive call or can dial 112 then lcd part is the problem. check the connector and all line connected with lcd. but if can't make call then the problem is iether firmware,ic's,upp.....
The Following User Says Thank You to robz For This Useful Post:
Old 01-09-2006, 06:26   #5 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
try flash your phone first but becareful it maybe make your cant on~~~~~~ because it drop set..........
Old 01-09-2006, 15:39   #6 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 11
try to change the upp i.c. or reflow it first... if it's the same prob. cahnge it much better then flash it again with a higher ver.... hope it will help
The Following User Says Thank You to jarniel For This Useful Post:
Old 01-09-2006, 21:37   #7 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
SORRY BUGS JUST VISIT HERE FOR SOLUTION
http:///vbb/showthread.php?t=261084
.:Javajohn:.
MOBILEWALA TEAM
The Following User Says Thank You to Javajohn For This Useful Post:
Old 01-10-2006, 02:17   #8 (permalink)
Member: 36741
Thanks Meter: 5
thank's for reply friends I have already check print of lcd connector by meter those all are okay and re flash also but the problem is still and also failed to make call and receive and mobilewala team my set is 7610 i am finding this chip as you shown in pic but i am not succes to find this plz show me in 7610 dears sorry for my loss english
Old 01-10-2006, 11:29   #9 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
Ok My Freind Just Take This Solution Of Urs 7610
The Following 5 Users Say Thank You to Javajohn For This Useful Post:
Old 01-15-2006, 10:03   #10 (permalink)
Member: 78236
Thanks Meter: 3
I have the same white screen problem. What will I do?
The Following User Says Thank You to jjfox04 For This Useful Post:
Old 01-15-2006, 16:46   #11 (permalink)
naughtycell's Avatar
Member: 214350
Thanks Meter: 17
Fall on ground ? in case it is typicaly like it .
I think the previous problems was from a ripped source under any IC - may be Flash mem. or Power or prossesing , any thing !!
or may be you didnt follow the link added by " javajhon " ? did you follow the instructions he supplyes ?
Or did you tryed another new LCD ?
The Following User Says Thank You to naughtycell For This Useful Post:
Old 01-16-2006, 08:42   #12 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
ya just follow the insturction u will succed
Old 01-17-2006, 00:30   #13 (permalink)
Member: 36741
Thanks Meter: 5
thank's guys but sorry at the moment my health not well after few days i 'll give result thank's again
Old 04-13-2006, 10:56   #14 (permalink)
Member: 244492
Thanks Meter: 8
is it the ic 4 7610 lets be sure
.:Javajohn:.
MOBILEWALA TEAM
Old 04-13-2006, 15:19   #15 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
White Light Hang??? First You Chek How Much Time Your Phone On.after Some Minut Your Phone Is Automatic Off Step Here...little Hard..but You Try..
1--replace Flash Ic Nomber K8S6415ETA.. If.same Problem...
2--reball Uem....if Same...
3--reball Cpu..upp... 100% Solv Your Problem Whit Light Hang....
But All Thish Do Befor Replace Black Ic Mation On Pic..near Ringer Ic....
Thanx..
The Following User Says Thank You to **RAJESH** For This Useful Post:
7610 white screen all calls incoming outgoing flashed many version still white screen GSMBALOCH Nokia Hardware & Hardware Repair 7 06-01-2009 20:54
7610 White Screen then Turns off, Urgent msas Nokia Hardware & Hardware Repair 8 11-15-2006 03:34
7610 white screen after flashing a ppm MELME UFS2 + UFS3-Tornadoflasher 29 05-05-2006 01:53
7610 white screen! reji Nokia Hardware & Hardware Repair 1 02-11-2006 15:47
Page generated in 0.30649 seconds with 10 queries
