07-24-2001, 21:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | 6150 Problems. Pls help The same is however different with a 1800 sim card. No problems with text and calls. But nevertheless of the 2 bands the signal seems weak and somtimes fluctuating. Any comments or suggestions..? Thanks! |
07-25-2001, 04:20 | #3 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | Hi cells r us. I have added info about problem... I have this 6150 that when you install battery and leave the phone off. It won't turn on the next day. The unit is self discharging even when off. Also, I tried testing the battery contacts: with + probe to + terminal and - probe to - terminal - and tester at x1 range... needle deflects when I switch the probes the needle deflects and stays deflected. Another problem is that the txt msgs in the 900 band lag, while the 1800 band is ok. Could you give me suggestions man? Thanks. |
07-25-2001, 21:27 | #6 (permalink) |
Freak Poster Join Date: Jul 2001
Member: 5364 Status: Offline Thanks Meter: 0 | By the way guys this works 4 me...most times... WEAK RF normally filters ,resolder,clean ,antenna. etc. Fluctuating RF normally PA Xtals etc. RF problems +charging or power & battery probs..PA |
07-27-2001, 02:34 | #9 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | I just pulled out the 900 mhz PA. I now can receive txt messages no problem. Also I checked the battery terminals for shorts and surely it is the 900 mhz PA shorted. I'll just try to observe the phone for a couple of days. I think it is ok to just leave the phone only with a 1800 PA... Is this ok? Keep you posted. Thanks again Fizz |
07-27-2001, 06:11 | #10 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | I observed that though I can receive txt msgs more reliably now that before I pulled out the 900 mhz PA, The signal seems to drop to 1-2 bars just before it the txt msgs arrive. What else could be giving in this phone? All suggestions are welcomed. Thanks! |
07-27-2001, 06:19 | #11 (permalink) | |
Member: 5246 Status: Offline Thanks Meter: 9 | Quote:
A3618 Problem. Pls Help! | Dj King | Sony Ericsson | 6 | 08-02-2003 02:17 |
Sony CMD-CD5 problem pls help | MaHuAk | Sony | 0 | 08-04-2002 04:29 |
s25 problem pls help me | MaHuAk | x1x to x45/x50 | 0 | 06-11-2002 21:53 |
Big PROBLEM!!!...pls. HELP!... IMEI (656565) LOCKS(4 CLOSED) CAN IT BE REPAIRED? | Chryse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 02-08-2002 07:16 |
alcatel 3xx dead problem !!! pls help!!! | gsm-lord | Alcatel TCL Hardware Repair | 6 | 11-13-2001 20:37 |
