Old 11-23-2002, 11:59   #1 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
6210 all locks closed.But can't open by all software???
I try to repair 4 locks on 6210 v5.56
As usually, I use Jordik's tool 3.21.but locks still closed.
Then I fullflash this phone (including eeprom), repair IMEI , FAID , open locks.
IMEI was repaired, but locks - not open again.
What's wrong???
I think , it's not software problem..
Old 11-23-2002, 14:10   #2 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
first full flash with good backup
and repair imei ,splock update faid
try with b-phreacks eeprom tool3.1
that will solve your problem
othervice chack with Wintesla
in 3310 it is cooman when components in cobba v ref to ground fails it shows all lock ffff
but no such case in 6210
Old 11-23-2002, 16:24   #3 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
I already try all software solutions
Old 11-23-2002, 18:02   #4 (permalink)
Member: 1060
Thanks Meter: 10
Re: 6210 all locks closed.But can't open by all software???
Invader
sound like your COBBA has problem
check MSID is ok or not !
might need to check flash rom too !
Willy
What's wrong???
Old 11-23-2002, 23:03   #5 (permalink)
Crazy Poster
Member: 17649
dct3 eeprom tools
Old 03-21-2003, 16:41   #6 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
Still can't repair tihs phone...
After each software reset MSID of phone becomes different.
In official service people try to change Cobba but without success.
Any idea?
P.S. ALL SOFTWARE solution can't help me.
All software tests is OK (I use old soft PCLocals for it, WinTesla don't work on my notebook :-(( )
Old 03-22-2003, 01:26   #7 (permalink)
Member: 11208
Thanks Meter: 11
Hi.
MAD,COBBA,CCONT,FLASH. Tested by me.
Old 03-22-2003, 11:11   #8 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
try to Change Cobba, Flash, Ram - still no result
will try to repair it...
Old 03-22-2003, 20:14   #9 (permalink)
Crazy Poster
Member: 17649
fault of PCB?
Old 03-22-2003, 21:07   #10 (permalink)
Member: 13596
I have same problem!!!
I change flash first time nothing(same problem)
but second flash was OK
Old 03-22-2003, 21:12   #11 (permalink)
Member: 13808
Thanks Meter: 163
use rolis 1.8 or 1.9, read phone click on FAID, then SP then read again to find out if it works
good luck
Old 03-22-2003, 21:22   #12 (permalink)
Member: 14223
Try a "partial" unlock flash file.
Old 03-23-2003, 16:51   #13 (permalink)
kharr's Avatar
Member: 11205
change cobba,
if it doesnt work try chekin it in wintesla
Old 03-25-2003, 15:44   #14 (permalink)
Member: 22526
If you change COBBA and the full flash , the problem is solved!
Good Luck!
B.R.
Old 03-26-2003, 10:30   #15 (permalink)
Springer's Avatar
Member: 15909
Change Cobba, and flash virgin eeprom. Use Knok Phoenix, and Rolis 1.8 for Imei Change.
Good luck!
6210 four locks closed [Rod] Nokia Hardware & Hardware Repair 9 04-26-2004 20:41
dead 6210 - 4 locks closed pico Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-19-2002 00:33
3310 v4.24 contact service and4 lock closed but automatically solved after sometime sidharthaharish Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-06-2002 19:52
6210 4 lock closed imei field damaged Salim Main Sales Section 0 01-03-2002 00:41
5110 v5.07 all lock closed - help Ziba Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-18-2001 16:57
Page generated in 0.19341 seconds with 9 queries
