Old 03-26-2003, 19:31   #16 (permalink)
Member: 14076
after removing COBBA check if you have missing pads on PCB!!
Old 03-26-2003, 21:05   #17 (permalink)
Member: 1778
Use eeprom tools 3.1, TEST item. If there are some problems with COBBA, It will tell You. Sometimes there are problems with COBBA IMEI REGISTER. Better way to replace COBBA, but may be some problems with eeprom too. I mean eeprom content, ofcourse.
Before making whatever repairings, just use test program.
WBR
Assen
Old 03-27-2003, 12:49   #18 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
Thank, I forgot about test option in EEprom Tools 3.1.
I receive following responce -
Bad DSP response!!
Possible reason -
1.Bad IMEI data
2.Faulty RF part
3.Missing Ariel
Imei OK (virgin eeprom was uploaded, then I correct IMEI )
what must I do now?
Old 03-27-2003, 13:16   #19 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
If you have triedall the software possibilities than it must be a hardware problem.I had similar problems on 3310 and 3330 and it was always some voltage from CCONT to COBBA missing!!!Use the schematics and check all the lines VCOBBA,VBB and VREF!!!
I`m sure that this is the solution!!!
Good luck!!!
Old 03-29-2003, 14:21   #20 (permalink)
Member: 23790
just yesterday had the same problem...all 4 locks locked and no response on any sw...i cant remember what i did...but everything as usual but one moment i disconnected battery...connected back again resetted soft and done...do everything as usual...inc eeprom etc...and after SP locks disconnect battery...post results...may be ive done something else...
6210 four locks closed [Rod] Nokia Hardware & Hardware Repair 9 04-26-2004 20:41
dead 6210 - 4 locks closed pico Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-19-2002 00:33
3310 v4.24 contact service and4 lock closed but automatically solved after sometime sidharthaharish Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-06-2002 19:52
6210 4 lock closed imei field damaged Salim Main Sales Section 0 01-03-2002 00:41
5110 v5.07 all lock closed - help Ziba Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-18-2001 16:57
Page generated in 0.13213 seconds with 9 queries
