Old 03-27-2002, 23:55   #1 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
6210 in bad shap!!!!!!
i've a 6210 that has fol down into wine and stay there for a minutes.them i've take it out and wait a few days until it as dry. them a dyas after i put in charge witn another batery becuase the onde that falls into the wine is dead and my surprise it starts charging. them i press on and the phone give light and blinkinf for 2 or 3 seconds and down stop charging and die . after two seconds it star charging again and i do the same and the phone responsed the same. and is finish. he stoped charging and rigt now it doesn't charge! what is the problem? whata can i do to give life again to my beautiful phone? please help me!!!!
thanks in advance!!!
Old 03-28-2002, 00:33   #2 (permalink)
Member: 7767
Thanks Meter: 3
Open it and You'll see many interesting things (after charging and powering up).
Old 03-28-2002, 03:19   #3 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
i've already open it vut i can't find the problem!!!!!please help!!!to return to action!!!thnaks!!1
Old 04-03-2002, 11:21   #4 (permalink)
Member: 6460
In the first place, you should not have put any
power supply unless you are sure that the unit is free
from any moisture.
Cobba IC and other BGA type and some other parts
may still have some moisture inside. In manufacturing
plant, some parts are even baked to make it moisture free.
For now, just try using hot-air and flux to revive ur phone.
But be very careful, Dont attempt to heat parts that are
sealed. Otherwise, it will be short-circuited and good bye cellphone.
Be carefull, 10 seconds of hot air is enough
Old 04-03-2002, 15:07   #5 (permalink)
Member: 8214
my suggestion is just open the phone and clean it first, be sure all the moistures are gone and flow the hot air. i hope it will work, if it is not working remove cobba clean it fix it again. We repaired some phone like this.
good luck
Old 04-04-2002, 21:40   #6 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
hello!i've already openm the hone and wait many weeks till it dry it should have no reasons to be still wet. and now there has a time when i put in charge and the phone didn't do nothing but now i put in charge and sometimes it apers the signal of abterry charging but gopes away and otheres times a trace a bla~ck trace on the screen. is this good. becuase a time ago id didn't respond to charge!!!!!
thanks.
Old 05-12-2004, 22:57   #7 (permalink)
Member: 11926
I have a similar problem
when connected to chager, indicator is always blinking.
Can anyone try to help me ?
Old 05-12-2004, 23:44   #8 (permalink)
Member: 39601
Thanks Meter: 13
@nooneO....
Clean the charging socket , or replace it.
GoodLuck
Old 05-12-2004, 23:56   #9 (permalink)
Member: 65406
Open phone and clear phone board in ultrasound tub.
Old 05-13-2004, 00:51   #10 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
First Try to clean the phone to be free of any wine residues. Use anything that vaporates after Cleaning and not alcohol. If it is available use ultrasonic and then maybe you can reflow some parts if neccesary.
I have found that PVC Glue remover some times can do a very good job and evaporates fast whithout damaging the parts.
Then you can check for damaged parts
6210 with bad MSid Joseph79 Nokia Hardware & Hardware Repair 2 01-18-2004 08:54
Using 6310/6210 in 3110 car-system yooukai Nokia Hardware & Hardware Repair 0 10-11-2002 13:51
6210 no/bad reception Bananeman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-31-2001 22:06
Page generated in 0.21883 seconds with 9 queries
