03-07-2003, 02:05 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | First try flashing on other pc. Reheat/resolder flash and CCONT. Be carefull with CPU if it is glued. If not helped change flash IC. Regards |
03-07-2003, 02:22 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | A little advice before desoldering glued components ! Try to flash with KNOK ! And before write flash, set on MISC menu emulate communication from *.fls file and then select your file that you're about to use for flashing ! And set write fls file to phone ; select the same file that you've chosen for emulate ; and don't change 0x2000000 adress which appearring and press ENTER ; Just press a little bit the switch ON for initialize the boot loader on phone ; Say a little HAIL MARY ... HAVE A NICE FLASH Max P.S. The battery needs to be full charged (it'll be better!) |
03-07-2003, 03:52 | #6 (permalink) |
Freak Poster Join Date: Mar 2003 Location: MNE Age: 43
Member: 23848 Status: Offline Thanks Meter: 13 | If you receive the same message with both flashers(flash erasing error or error on 48%) than the flash chip is bad!Try with Knok,klick on Erase the whole flash,if you receive the same message-that`s it! Forgot to mention-the flash can also be unsoldered or some line on the PCB is missing! |
03-07-2003, 16:33 | #7 (permalink) |
Freak Poster Join Date: Feb 2002 Location: davao, philippines Age: 43
Member: 9398 Status: Offline Thanks Meter: 1 | hey mates... tnx for ur replies.. problem is solved by just reheating flash ic... now i can turn it on.. but no signal.. but i guess pa or maybe antenna switch is just the problem... tnx guys... i love this forum!!!! br, wamir |
Erase file and erase flash procedure | realtech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 03-22-2010 21:02 |
6210 v3.01 erasing flash cmd error | thagangsta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-08-2002 01:16 |
6210 dead!!!! Erase flash error, pleas help me! | alro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2002 22:16 |
6210 5.17 - Erase Flash Error | abuissa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-19-2001 01:47 |
