03-26-2002, 03:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | 6210 no neetwork!!!!! |
03-28-2002, 14:57 | #3 (permalink) |
Insane Poster Join Date: Sep 2001 Location: Philippines
Member: 6460 Status: Offline Thanks Meter: 1 | if software will not solve. then its time to consider as hardware problem. try first the antenna as suggested above. desolder or replace RF parts. For detailed reference you must have service manual. try to get one from landys page http://eh.student.utwente.nl/%7Elandy/ |
04-02-2002, 15:33 | #5 (permalink) |
Freak Poster Join Date: Dec 2001
Member: 8214 Status: Offline Thanks Meter: 0 | May be a stupid doubt..... if it is a soft. problem, how it is solve the mcu+ppm flash, from my experience it won't work, if u upload a full flash and clear imei and calculate faid it should work.... regards |
04-03-2002, 07:11 | #6 (permalink) |
Member: 9502 Status: Offline Thanks Meter: 9 | no software problem is not!!!! software i've tryed everithing! tell me where can i find all that material to repair nokias like a good ssodering station and osciloscope and anyone can tell the references of good material and at good price????? please reply! thanks in advance! |
04-03-2002, 10:09 | #7 (permalink) |
Member: 6460 Status: Offline Thanks Meter: 1 | to gazt: landys user: mobile pass: elibom to sergioems: Soldering station will cost u about $200-300 Forget the oscilloscope 100Mhz it will cost u about $1000. Aside from osc, you need 1800 Mhz rf gen. as a start, buy only hot air-soldering station |
04-13-2002, 05:42 | #8 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi, For all new man here. To resolve harware problems you should have fistly: 01- hot air solder/desolder 02- Multimeter 03- You should have the manual service of the phone When you have all this, contact me to give you the method and the description of repairation. Tahnks |
04-15-2002, 02:54 | #9 (permalink) |
Member: 7934 Status: Offline Thanks Meter: 0 | Hi, The problem can be software or hardwre. If it is a software one try rejiv has told, else follow the steps descripted by our friends. If not ok contact me again. bye |
04-17-2002, 20:16 | #10 (permalink) |
No Life Poster Join Date: Jan 2001 Location: UAC Age: 54
Member: 2993 Status: Offline Thanks Meter: 9 | hi, if it is not soft problem try this: 1 resolder cobba ic (with ir station if possible) check duplexer filter and pa module, usually is pa broken or cobba whith bad solder ciao |
04-19-2002, 01:06 | #11 (permalink) |
No Life Poster Join Date: Oct 2001 Location: n east
Member: 6705 Status: Offline Thanks Meter: 24 | signal loss i have 3 8210 handsets with signal problems which is hard not software can any body help me with these as well as 6210 signal faults # many thanks in advance |
04-19-2002, 01:30 | #12 (permalink) |
Member: 2993 Status: Offline Thanks Meter: 9 | TO SMARTYMARTY HI, low signal or loss signal ,the problem it is the same, in 80% of phone you must resolder cobba ic ,in the rest of phone may be have rf pa module broken or duplexer. the pa module is built into ceramic support and if the phone fall down.... remeber that in the nokia phone if tx is ko it not rx because the phone must send the data( imsi etc)after it show the net . in the other model of phone ( ericsson samsung ) rx and tx are separate ciao mirko |
N 6210 no ring and no vibrate.... solution?? | UnlockZonen | Nokia Hardware & Hardware Repair | 9 | 07-03-2006 11:48 |
3100 no neetwork | ahmed111980 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-05-2005 00:27 |
6210 no audio, no ring, after full flashing | baraka42 | Nokia Hardware & Hardware Repair | 5 | 07-09-2003 09:13 |
6210 no ring, no Mbus | kage | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-13-2002 15:33 |
6210 no neetwork!!!!! | sergioems | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-27-2002 04:40 |
