08-12-2001, 08:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | 6210 pwoer-off when presssing any key !! if i leave phone .. no power-off .. just power-off if i tried to press any key . !!! help me |
08-13-2001, 09:46 | #2 (permalink) |
Insane Poster Join Date: Aug 2001 Location: bulgaria
Member: 5750 Status: Offline Thanks Meter: 0 | Hi.<br />Such problem is tipical when power switch is defect (shorted)<br />may b your nokia is swithing on after inserting the bat ,and switches off<br />when any key is pressed .<br />So u must open the phone and check the switch .<br />and of course change it ,if u can't find this part (it is smd ),also check the elements on PWRONX line for grounding ,bad solder,e t. c.<br />u may try to disasemble the switch and clean it (this is delicate <br />component so b carefull ) after it will work .<br />How to test the switch ?<br />open the phone ,remove keyboard pcb and place bat in the back <br />cover now place the board upside so it can contact to the bat secure it <br />with 2 screws measure the voltage between the two pads of the <br />switch when it is not pressed it may b 2,6-3V and when is preseed <br />must be under 0.5 V in your case i suggest it is under 0.5 <br />constantly .<br />the flip button and some other keys give interrupt to the MAD <br />and it switches off the phone . <br />The cause of such problems is the dirt inside the switch or<br />switch destruction after strong pressing .<br />good luck but if u cant buy such button first try to clear it <br />with drop of alcohol(isopropil is better )then pres it few times and <br />measure again.<br />By. |
sony ericsson k790i keypad 8 key problem swicth off when press 8 key | narayan_shahane | Sony Ericsson Hardware Repair | 6 | 01-20-2011 06:38 |
big problem,i phone key board runs when typeing any key.help | ARAB GSM | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 06-13-2008 16:06 |
L6i TURN OFF WHEN PRESS ANY KEY | jamohaki | Motorola P2k | 1 | 05-13-2008 10:26 |
6210 power off when press a any key | Sakura | Nokia Hardware & Hardware Repair | 3 | 09-21-2003 11:23 |
Sl45 Power OFF when pressing DOWN KEY! | ARC | x1x to x45/x50 | 2 | 11-22-2002 22:01 |
