12-08-2004, 12:55 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 36
Member: 96449 Status: Offline Thanks Meter: 0 | 6210 shut down when pincode is asked sometimes I can push some buttons. But no pincode-stars appear on the screen. then he falls out. Most of the time he falls out before you can push any button. I tought it would be the battery, so I replaced it with the one from my current 6310. Same problem. And If I place the 6210 battery in my 6310, it works fine. Any suggestions? thx in advance! |
12-08-2004, 14:31 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Uranus Age: 53
Member: 5072 Status: Offline Thanks Meter: 91 | if you are able to enter the pin code and then the phone turns off .........its probably the PA that needs to be changed .....BUT .....if the phone switches off as soon as you are trying to enter the pin code ( pressing any button ) The The Rubber part that press the On/OFF button is probably jammed .............open the phone and re-pack it ...check again and post results here rgds |
12-08-2004, 17:24 | #5 (permalink) | |
Member: 96449 Status: Offline Thanks Meter: 0 | Quote:
I opened the phone, re-packed it.(to check button-jam) First it was still the same prob. As I kept trying, I could set the time.... set the date.... After endless trying, the phone accuatly is working. When the phones crashes again,I need enless trying again to get the phone back on. When the phone workes(for maxiumum a few minutes), it seemes to craches, but is then suddenly back on, without asking the pincode I also removed the power button, (little rubber) But no progress. (hopefully everthing is clear because my Englisch it not good) | |
12-08-2004, 18:09 | #6 (permalink) |
Member: 5072 Status: Offline Thanks Meter: 91 | ok ........its a reboot problem ......and it can be caused by any of the following . Software corruption .....flash the phone .....do a full factory reset too. Power IC (CCONT ) Apply flux paste .....and reflow ......or change the IC. Also please do the following ...remove the PA and see how the phone behaves without the PA .......obviously it wont have a signal ......but does it still reboot? When you say "the phone Crashes" what do you mean ? It switches of and switches on again ? and it does not ask for the Pin code ....it directly shows the signal.....or it hangs? and the battery has to be removed? this problem seems to be a power supply fault .......and it is probably cuaused by Dry solder........ Soon i will be making Video Clippings where we will show people how to repair various hardware faults ....and posting them on my website for all to download .........We will show everything as clearly as possible and i hope it will be easy for all to understand and learn Rgds, themobileking |
12-08-2004, 18:21 | #7 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | Also look to me like water or liquid damaged phone : I will advise befor you start themobileking's orientation try to clean your whole pcb and rehot , then fibre clean your keypad swicth (change membrane if coroded) and you will get got result from the above post. cheers |
12-08-2004, 19:38 | #8 (permalink) |
Member: 96449 Status: Offline Thanks Meter: 0 | My knowledge is very primitive so I can't do all of the things. Once the phone reached the main screen. I can scroll in the menu's. But the problems start when I type a message, shange date or time ect, The phones crashes to the menu.(freezes for 3 seconds--> screen off for 1/2 of a second -->an empty lighted screen for a few seconds -->then back on the main screen) I'm not able to fill in the security code for resetting to facility settings. By the time I filled in the forth number, the phone crashes (like descripted above). I only get a full cash when the phone is still starting up, or rarely in the menu's. (The battery dont' have to be removed to get back on). then he automaticly starts up again..(then he askes pincode again) [quote]Power IC (CCONT ) Apply flux paste .....and reflow ......or change the IC.[\quote] first have to find out what all those things mean, so later maybe. I don't know what a PA looks like , But after I removed a platic object that was attached with a torx screw, I didn't had operator signal. @keke as far as I know the phone is not damaged by water Making video's would be a great idea!! |
6100 shuts down when entering gallery menu | Alinus | Griffin | 1 | 03-15-2004 02:12 |
ME45 shuts down when transmiting | covex | Siemens Hardware Repair Area | 5 | 03-09-2004 11:36 |
motorola v50 shuts down when power up | crossings | Motorola Hardware Repair | 4 | 11-01-2003 12:05 |
M35 shuts down when recharging li-ion | trol4oBG | x1x to x45/x50 | 12 | 09-02-2003 19:46 |
M35 shuts down when recharging li-ion | trol4oBG | x1x to x45/x50 | 0 | 07-17-2003 13:36 |
