11-13-2003, 14:38 | #3 (permalink) |
Freak Poster Join Date: Oct 2001 Location: NIS
Member: 6781 Status: Offline Thanks Meter: 0 | see service manuals...and check filters for 900Mhz....but first....you should first use wintesla to see if HF/HFR is used...or not used.....if is not used....use full factory with wintesla...and turn them on!!!!!!!...POST result |
11-15-2003, 22:03 | #5 (permalink) |
Member: 6781 Status: Offline Thanks Meter: 0 | this is chanels....you should keep them open....hmmm....you have cracked version of wintesla...and you can use thet version....try to find it on net..when you find one....post me i will learn you how to check TX/RX and how to open HF/HFR |
11-16-2003, 22:42 | #8 (permalink) |
Member: 6781 Status: Offline Thanks Meter: 0 | @medz one chanel you can turn on and off from kayboard...*3370*/*3370#...you can read about it in nokia service manual....to see the effect....other chanal...easy....use option in wintesla.."product profile"...if you see that HF/HFR not used....use option full factory reset.....to open it..... for measuring rx/tx foult...with wintesla....you can ICQ...me....to help you.. |
11-18-2003, 00:11 | #9 (permalink) |
Freak Poster Join Date: May 2002 Location: tunisia Age: 64
Member: 12001 Status: Offline Thanks Meter: 3 | Medz an external antenna is like a switch, if there is bad contact there it causes a week signal, what we can do, replace the external antenna or short cut it. |
nokia 2100 weak signals | Shahrukh | Nokia Hardware & Hardware Repair | 16 | 06-22-2009 18:59 |
3310 very weak signal | ficho | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-30-2003 21:14 |
t28 weak signal | .::AkhavanGSM::. | Sony Ericsson Hardware Repair | 7 | 10-24-2003 21:08 |
sgh-r200 weak signal/no service | phoneshack | VLSI, Conexant, Skyworks and Old Models | 2 | 10-18-2002 11:44 |
8210 ... & ...6210 weak signal problem..call drops...sinal drop | PTR999 | Nokia Hardware & Hardware Repair | 3 | 04-17-2002 14:06 |
