07-31-2006, 16:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | 6230 all sound not working Could this be the uem,but its eproxied? |
08-01-2006, 04:19 | #2 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Adelaide Australia Age: 39
Member: 96184 Status: Offline Thanks Meter: 6 | you need to replace the AF amp which is located next to the battery terminal and the current sensor. the AF amp and current sensor look very similar. the AF amp is the square shape black or shiney silver ic. |
08-02-2006, 17:58 | #3 (permalink) | |
Member: 173565 Status: Offline Thanks Meter: 71 | Quote:
Yes I already done that still the same,I change the uem all ok,thanks. | |
10-17-2006, 12:06 | #6 (permalink) |
Junior Member Join Date: Jan 2005 Age: 45
Member: 108631 Status: Offline Thanks Meter: 0 | same problem, nokia 6230i without sound I have the same problem, nokia 6230i that suddenly doesn't have melody snido. Such and like you put here I have replaced him FM the amp, component that this near one to the foto/video camera and that he/she has the following reference: MAH Z614, the color of the FM amp of the 6230i is silver (ic). I have caught the FM amp of a nokia 6230 that it is of black color, I have put it at the 6230i and it continues equally, without sound. Can somebody tell me if I am changing the appropriate component? Does Alquien have picture of the badge to indicate me the exact component that it is necessary to change? Can somebody tell me if the FM amp has to be of color silver (ic) or should it also work him that of the 6230? I expect your help, thank you |
10-17-2006, 12:46 | #7 (permalink) |
Freak Poster Join Date: Sep 2005 Location: USA Age: 58
Member: 176971 Status: Offline Thanks Meter: 116 | 6230 or 6230i...it is the same audio ic. 6230buz.JPG |
The Following User Says Thank You to edi_vladut For This Useful Post: |
02-08-2007, 19:24 | #8 (permalink) | |
Freak Poster Join Date: Jun 2003
Member: 31448 Status: Offline Thanks Meter: 1 | Quote:
03-19-2007, 17:58 | #9 (permalink) | |
Junior Member Join Date: Mar 2006 Location: S.joćo da Madeira
Member: 239338 Status: Offline Thanks Meter: 0 | Quote:
Problem with water. I Chang it and works ok. Good work bro! Regards, gsm_suave | |
Nokia 6230 Some keys not working | adeel786 | Nokia Hardware & Hardware Repair | 5 | 03-27-2010 08:01 |
6230 i Mic not working | abdullatheef | Nokia Hardware & Hardware Repair | 3 | 05-07-2006 12:24 |
6230 menu key not working | The Repair Shop | Nokia Hardware & Hardware Repair | 9 | 11-07-2005 20:38 |
6230 unlock codes not working | twisterfan | Twisterflasher | 5 | 07-21-2005 17:44 |
Did Smart-clip mess up a V220? Camera/sound not working | GeeZuZz | Smart-Clip | 13 | 03-30-2005 11:33 |
