6230 flash not work hi , 6230 can flash cnt not compleat but if flash mcu+ppm can flash compleat and phone is not boot in local mode, not write pm file, not info 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x027FFFFF,00EC0039,Sam KEE00E00CM Algorithm: te_amd_b.fia Algorithm Ok, MSID: 8422DB2C222CC183C3679BCDF0 Decoded MSID: D3EBBAE9-00C53F45-A8000000 Encoded FAID: 35D9A31B-87A3C667-2411F20F Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x007FFFFF Erased, Time: 01:06 Area3: 0x00800000-0x0093FFFF Erased, Time: 00:10 Area4: 0x00B60000-0x00FEFFFF Erased, Time: 00:38 MCU Flashing Completed, Time: 00:51 Area1: 0x00940000-0x00B3FFFF Erased, Time: 00:16 CNT Flashing Completed, Time: 00:09 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile now I chang UEM ,FLASH k8s2815et,flash kee00e00cm but phone ia same promblem **when I flash mcu compleat and phone is extacting contens phon is strat up power on and off every time please help me fo fix thia prombl :confused: em |
Hi, please help me pleasezzzzzzzzzzzzzzzzzz |
first try change crystal 32..... check RF ic |
Hi, anno Thank for help me but I chang 32k and helga ic and I have same promblem How do you think |
Mey you have track damage . 5% you can repair this phone. Try change RAM ic. no result. send phone to sphare parts. |
change only ram ic its save in contents file |
Thank for idea I test is you tell me and If I have problem I just post again |
hey ssot try to flash first witout content package if ok then try agen |
i have the same problem and i full erase and just flash only MCU and PPM only , and then try to start it and the same problem and then i think it is hardware problem |
