03-15-2006, 14:59 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | well, i have some little that can help you. 1. powering on your phone !!!! 2.battery is the most important part of the phone performed to do duties. 3.power on supply modules on phone such as ic's and cpu units. 4.PCB unit is important to know. 5.on/off key is there. 6.back - up battery inside the phone. 7.battery tips for battery connector to flow current in to the phone. 8.flash Rom in the phone board. 9.cpu is important , all area around the cpu , the pins attachments to the cpu unit. 10. Ram of the phone !!!! 11.the clock amplifier to your phone. common error to your phone . 1.wrong flashing files. 2.wrong application tricks to phone. 3.overcharging battery to phone . 4.wrong charger to your phone can check this problem. 5.power ic's unit can be unsoldered well , after poor use of phone. 6.contact with water . bestman |
03-17-2006, 14:54 | #4 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: SA TO UK
Member: 136823 Status: Offline Thanks Meter: 50 | Ber Quote:
My advice close it up and move on to the next. If anyone else has another solution i am always ready to listen. Regards | |
nokia 3530 power switch track broken....plz help.where to put jumper wire?????? | RAHUL12345 | Nokia Hardware & Hardware Repair | 6 | 05-28-2013 04:29 |
nokia 6100 power switch track or positive ways | barthosyn | Nokia Hardware & Hardware Repair | 18 | 12-12-2009 07:01 |
help 3105 power switch tracks (pls see. image) | ufs_ternoda | Nokia CDMA | 3 | 09-11-2007 22:09 |
help 3105 power switch tracks | ufs_ternoda | Nokia CDMA | 0 | 08-01-2007 16:57 |
3220 power switch track | yandbass | Nokia Hardware & Hardware Repair | 8 | 09-29-2006 21:31 |
