12-03-2005, 11:52 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | connect phone on ~4V PSU with main board open in your hands check voltage at one side of volume switch, should be a few volt other side 0V when switch open. close switch and voltage should drop to zero volt each side. if that is not happen then your switch is faulty so replace. if there is no voltage on either side of switch then you must fault find supply components near to switch 8) |
6120 volume key problem.... | jimmyyew1981 | Nokia Hardware & Hardware Repair | 2 | 01-20-2011 15:00 |
6500s upper volume key problem | luyanda | Nokia Hardware & Hardware Repair | 6 | 09-06-2010 10:20 |
n73 up volume key problem | khm050 | Nokia Hardware & Hardware Repair | 3 | 09-12-2009 03:17 |
6230 volume key pad schematiks. | kommandos | Nokia Hardware & Hardware Repair | 2 | 03-17-2009 11:27 |
5610 volume key problem | mithon | Nokia Hardware & Hardware Repair | 2 | 11-29-2008 08:10 |
