Old 06-07-2006, 10:06   #1 (permalink)
Member: 210449
Thanks Meter: 2
regarding nokia 2100,flashed bt still
hi dear friends
hope all r fine.
well im having problm on nokia 21oo. it showed contact service. whn i flased wt ufs 3 flasher,and again i setted the UI Setting too.
bt still showing "contact service"
hw can i fix this problem??
pls
thanks in advance
wt lov
Old 06-07-2006, 11:42   #2 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
erase flash and try to flash the phone and good pmm(attachment)init simlock and full factory.........regards
Old 06-07-2006, 11:56   #3 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
unlock with noktool18 it will solve your problem 100%
Old 06-07-2006, 12:07   #4 (permalink)
mailhassan's Avatar
Member: 23834
Thanks Meter: 27
here's a 100% for use with ufs;
do full erase, write full flash mcu.ppm and good pmm.
do rebuild imei, then check all ui settings.
phone must be ok.
Old 08-14-2006, 18:23   #5 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Hi some times contact service can be caused by hard ware fault.So if you have try to reflash but still problem un solved try to reball or change cobba ic.
Old 08-15-2006, 00:02   #6 (permalink)
Member: 322577
Thanks Meter: 6
PLS I WANT TO KNOW YOUR LOCATION AS WELL AS YOU E;MAIL ADD.BCOS OF FUTHER THING TO LET ME KNOW ABOUT.I HAVE CHANGE THE COBBA WITH LUCKY SMD MODEL NO. 852D & THE PHONE DIES THEREFORE I W ANT TO KNOW GOOD EQUIPMENT USE TO CHANGE THE IC, LIKE 3310 CCONT, 2100 COBBA AND OTHER BGA ICS.
Old 08-15-2006, 09:44   #7 (permalink)
Member: 251413
HI, I have a 3610 contact service when flash with ufs it's shows..
1st Boot Ok
2nd Boot Ok, DCT3, MAD: A1 G-01, ROM: 6, BUS: 16
FLID: 008988C2,Int 28F1602C3-T, I28f160.tia
Software:
Algorithm Ok, [185A]
Erasing: 0x00200000-0x0048FFFF
Erasing Error: 10,at: 0x00400000-0040FFFF, 910206
Process Failed, Repowering Mobile
Any solution?? Please help me...thanks.
Old 08-15-2006, 10:06   #8 (permalink)
Member: 81214
Thanks Meter: 2
full flash 2100 after that rebuild imei, when imei rebuile remove last - from imei after do ui setting phone will be ok.
Old 09-30-2006, 09:13   #9 (permalink)
Member: 253546
Thanks Meter: 21
Dear Friend kardelen gsm
problem solved with ur method and pmm file,but there's no signals on my phone.kindly help me on this
thax
Old 09-30-2006, 09:40   #10 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
Smile
Originally Posted by shinojmahe View Post
hi dear friends
hope all r fine.
pls
thanks in advance
wt lov
take info of your phone if cobba id is 000000000000 then 100 % it hardware fult chang cobba ic and flash again. if coba id is ok then flash with good mcu , ppm, and pmm .after flash u will see c.s. on phone .not to warry .just rebulit imei and selact all ui opation and prass ui satting butan. after ui phone will ok 100% full network
abhishek
Old 09-30-2006, 09:50   #11 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
Smile
1st Boot Ok
Software:
well fualt in flash ic u can try with skip erase near right side chak this option and flash again .if it is not work rehot or reboll flash and flash again or chang flash.
abhishek
nokia 2100 contact service --still problem after flash--- crossings Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 49 11-11-2007 17:06
nokia 2100 flashed ok but can not power on barthosyn Nokia Hardware & Hardware Repair 6 12-16-2005 02:04
Nokia 2100 flashing ???????? xacker Nokia Multimedia 1 09-29-2003 22:38
Page generated in 0.18571 seconds with 10 queries
