6260 after 4 seconds Hi guy's! ı have a problem on my mobile phone which is nokia 6260 when ı switch it on there is no sign on the screen just light on it and also after 4 seconds it switches off.I flashed on it with griffin and twister programs but nothing changed on it what can ı do about this problem? I am waiting for your help.And also ı couldn't find erase file for 6260 but ı used 7610, 6600,7250i erase file on it. |
check your lcd print . |
thanks for your answer but ı tested bord on anhoder 6260 same problem! |
rehot uem or reboll uem ic. |
yeah you must change uem ıc |
hi first make ask and rpl and write same imei to flash if not work change uem |
hi guy's ı changed uem but stıll same problem ı dont know how can ı do it!! |
i have also this problem any idea |
hi guys i have a problem with my 6600 there is no signal only in one network can you help me? to solve this problem. even i change my uem, helga too. it doesn't show any signal |
i have this sme problem :) but when i change flash version it was working few hours, then again dead, I think ther must be someware bad conection, I was too check lcd print hmmmmmmm |
well... after all that experiance in dct-4 problems cann't u conclude that white lcd of wd2 phones if it couldn't be solved by software then it is flash or UPP ic ? it is clear like the sun ;) ....if not softwareproblem then remove the ram, flash, upp and place them back regards... |
guys guys i fund it :):)::)):) we are the chapions :) , i will send you photo leater, |
check the lcd to confirm that bu if still try to flash it again |
this is not lcd or uem or lcd print Leater i will some read and show photos what i do |
