02-10-2007, 16:49 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 374225 Status: Offline Thanks Meter: 41 | 6260 dead 1st Boot Err: Bad Resp UPP, 02 FF FF 72 1st Boot Err: Bad Resp DCT3 Rebooting Mobile now i reballed both the two flash ics again now m having this error 1st Boot Err: Bad Resp UPP, 02 FF FF 72 1st Boot Ok 1st Boot Err: Rebooting Mobile IM TOTALLY CONFUSED WAT TO DO NOW...PLZ HELP ME |
02-10-2007, 16:58 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | u done wrong u no need to reball ic in first problem just clean connectors and restart urs software..and if need then clean pcb also ..so urs phone take flash and working but now u maked problem in hardware ..u reball ic..and now possible that these ic are damage..so now reball again that ic ..and clean them and try flash.. if not ..then u must need to change these ic .. BR |
02-11-2007, 03:46 | #6 (permalink) | |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | Quote:
6260 have different flash ic... you cannot use 6600 flash.... they are same with 3230.... you might use st brand from 7610 or 6670..... br | |
02-12-2007, 03:32 | #10 (permalink) | |
as i see on your first post.... and your log.... you have problem with the first boot... look like upp is faulty... if i were you these are my procedures.. reball or replace upp.. check the log again.. on your ufs or jaf.... if the log like this in ufs first boot ok wd2........ upp might ok.... try to flash now.. but if the ufs doesnt read a flash id.... then you have to reball those flash ic..... post result.. luck buddy.. wbr | |
6260 dead affter flashing with griffin | andrews | WD2 & APE (Symbian Phones) | 19 | 05-14-2006 14:52 |
6260 dead | paklink | Griffin | 4 | 08-01-2005 21:06 |
6260 dead after flashing. | grace | powerflasher | 4 | 07-21-2005 10:59 |
6260 Dead after Flash erase ? | myrocky | UFS2 + UFS3-Tornadoflasher | 0 | 05-12-2005 06:30 |
