6260 not charging I have 6260 that suddenly stopped charging.I need a solution to this. Thanks in advance |
Didi you check the fuse above the batery conector? |
How do I know which one is the fuse?,and what should with it.Change it or what?.I saw 3 three things above the charger,one is just black,the other one has black in the middle and silver on both sides while the other one is a little more smaller with K written on it. Thanks in advance. |
yes dear K is fuse, chk all charging component components . for component look at the diagram |
Thank you very much but what do I check here,if it has a loose contact or test it with multitester to see if it is still good? and where is the diagram? |
I followed your pic and everything is fine.I used my multitester and the connection was fine |
IF it sows directly not charging to a screen than check the pin connectivity and its components related to middle pin of the battery connector |
