Old 12-10-2007, 14:42   #1 (permalink)
Member: 609370
Thanks Meter: 13
6600 Dead-1st Boot Error:02 Ff Ff 72--is It Uem Problem?
I HAVE A 6600 DEAD.
WHEN FLASHED IN UFS GOT THE ERROR AS BELOW
1st Boot Err: Bad Resp UPP, 02 FF FF 72
Process Failed, Repowering Mobile
I THINK FIRST BOOT ERROR 02 IS DUE TO UEM-AM I RIGHT?
THANK U
Old 12-10-2007, 16:04   #2 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Its not uem its flash ic.Try to reflow and reflash it
Old 12-10-2007, 17:51   #3 (permalink)
Member: 609370
Thanks Meter: 13
r u sure its flash problem?
i think problem in power section --if power section ok=some more steps forward in software--but in this 6600 error in first step--so i think its uem problem.AM I RIGHT?
HARDWARE EXPERTS HELP ME
Old 12-10-2007, 19:23   #4 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
if 1st Boot Error, u must cek :
1.vcoreA=1,5v
2.vio=1,8v
3.purx=1,8v
4.sleepclk= 32 khz
5.rf clk= 26mhz
Old 01-10-2008, 08:05   #5 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
Cool
1.vcoreA=1,5v
2.vio=1,8v
3.purx=1,8v
4.sleepclk= 32 khz
5.rf clk= 26mhz
Sir.
Can you give me a problem of each one???
or what i do if not normal of each one?
GsmJoman
Tc
Old 01-11-2008, 19:46   #6 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
1.vcoreA=1,5v
2.vio=1,8v
3.purx=1,8v
4.sleepclk= 32 khz
5.rf clk= 26mhz
6.vr3= 2,8v
7.vana=2,8v
if ur phone 1st boot error and u must cek voltage for booting cpu
if not normal each one reply me ur voltage and i will help u to give solution for 1 st boot error!!
Old 06-15-2008, 10:48   #7 (permalink)
Member: 677457
Thanks Meter: 6
is zocus is bad, are it possible we can flash the phone?
Old 06-15-2008, 15:09   #8 (permalink)
sureshlion's Avatar
Member: 700441
Thanks Meter: 71
yuva
6600
MCU ID: 0x1081
Error reading flashid...
Old 06-15-2008, 15:29   #9 (permalink)
Member: 734700
Thanks Meter: 14
cpu chang than full flash
Old 09-19-2008, 05:10   #10 (permalink)
Member: 691334
Thanks Meter: 140
1.vcoreA=1,5v
2.vio=1,8v
3.purx=1,8v
4.sleepclk= 32 khz
5.rf clk= 26mhz
6.vr3= 2,8v
7.vana=2,8v
sir what is vcoea-vio-purx-vana etc mean please i search for all the forum i am not fin answer any boody help me
Old 09-19-2008, 05:39   #11 (permalink)
Member: 726759
Thanks Meter: 28
Originally Posted by zone2 View Post
I HAVE A 6600 DEAD.
THANK U
replace smps ic and check battery cont ur problem will be solved
www.xual.page.tl
Is this UEM problem or still software problem??? tenso MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-25-2009 05:51
6630 dead-1st boot ok-logs posted-help zone2 HWK 0 11-05-2007 04:57
3510i: no network, on manual search very fast "NO network" info is it UEM ? PSG Nokia Hardware & Hardware Repair 3 10-09-2006 08:47
L6 dead with boot version 0.ff wazim187 Smart-Clip 6 03-03-2006 19:08
Page generated in 0.28073 seconds with 9 queries
