6270 lcd no light I have a 6270 damaged by water. I remove oxide, and after that the phone works fine but there isn't light on display. Keypad light works fine.The display is ok. I see schematic but there is only the main board. I need upper side scheme. Thanks in advance. Best regards |
Did u try changing flex and checked both flex connectors?Problem might be caused by UI PWB (upper PWB) try changing this. BR Janar |
white led on upper side works fine... I think that water damaged a wire, so I need upper side scheme |
search and you have the solution....... |
before to open this thread I have used search button with key: 6270 lcd light , but I don't have found solution... |
u may check lcd, UI board, flex cable, connector, led driver ( behind tahvoo ) ---- Byte |
thanks for reply, I am sure that: -lcd works fine; -flex cable works fine; -main board works fine; lcd board was damaged by water so a wire was interrupted and into schematic there isn't scheme about lcd board... I don't know the pin with lcd backlight into lcd connector. Thanks in advance B.R. |
into lcd board I have 18V, but probably there is a wire broken... I am looking for lcd connector pinout Thanks in advance B.R. |
---- Byte |
...I don't have a working lcd board... |
With the picture posted by vinay_sharma i fix my problem. Here the solution: http://forum.gsmhosting.com/vbb/show...&postcount=479 Many thanks to vinay_sharma :) |
patrik .b i have same prob can you explaine that pic (vinary_sharma) the up kepad ligth work but LCD light is not work ? |
