05-22-2007, 08:53 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | 6280 Display go black.. after few seconds.. |
05-22-2007, 11:27 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | which ic?. do you know that , if you cannot remove ic's very well, your phone ,will not powered on again. i have a question, are you sure - you have remove an ic's before? ic's are diffcult to fix. And sometime, if you remove, you cannot fix back to same position. please, suggest hardware first, this can help your suggestion better. Bestman |
05-22-2007, 11:37 | #6 (permalink) |
Member: 61294 Status: Offline Thanks Meter: 49 | have try replacing lcd?. have try checking for light diode on board?. have try checking flex connecting your lcd?. please, stop flashing your mob' now. i am waiting for you. Bestman |
05-22-2007, 11:44 | #7 (permalink) |
05-22-2007, 11:57 | #9 (permalink) | |
Freak Poster Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | change strip Quote:
05-22-2007, 16:53 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | solution for this problem from my expirence is 1. flash phone and make fectory. 2. change LCD 3. change flex cable. 4. change uper keypad (sometimes make this problem or light problem.) if lcd is good first start and then goes away , i think those will fix.... for no display at all first need to check the black IC near BT module , this ic also make no display. |
@@..1112,1200,1208,1202,1203, Lcd blank going Off after Few seconds 100000% Solve..@@ | mobi_soft | Nokia Hardware & Hardware Repair | 47 | 09-18-2014 07:43 |
1112,1110,1200,1208,1202,1203, Lcd blank going Off after Few seconds 100000% Solution | ssamji | Nokia Hardware & Hardware Repair | 20 | 10-09-2010 19:15 |
Nokia 1112,1110,1200,1208,1202,1203, Lcd going Off after Few seconds 100000% Solution | madni shah | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 04-28-2010 16:02 |
1112,1110,1200,1208,1202,1203, Lcd blank going Off after Few seconds 100000% Solution | madni shah | Nokia Hardware & Hardware Repair | 4 | 12-26-2009 14:56 |
