6280 hang,restart and camera "operation failed" plz hlp, 6280 hangs and restarts. also camera failed. i flashed the phone with v5.92 still same. |
u need to change the strip.... 10000000% |
wath is strip? i dont understand it |
he means the flexy cable . but sometime it not that ,it might be others factor . try ,goodluck . |
Changen The Flex Cable And The Ui Board, That Will Resolve The Issue, Bro |
Anyone has done the solution? Tried already changing the flex and lcd, firmware updated to v5.92 bu still same problem. |
hey bro change the ui board now. where the answer and nav keys are, that will do the trick. |
6280 hang,restart and camera "operation failed" CHANGE FLAT CABLE VORCK FOR ME I CAHGES ON 5 PIESES BEFORE FIVE MONTH VITH THIS PROBLEM AND IT IS OK BEST REGARDS |
i thing its not only the flat cample problem .... i thing maybe in some phones the problem will be at the board of keys (down of LCD) ........ |
6280 Changen The Flex Cable And 100% h/w problem set is ok |
this falt 75% strip first of all change the cabel abd next stap sotwhere.(br) ..::Mr Fone::.. |
i try it but cannot also.any solution |
