Old 07-07-2008, 10:25   #1 (permalink)
NAVEED74's Avatar
Member: 188574
Sonork: 100.1590742
Thanks Meter: 751
7610 Showing Error. THIS SAME POST I POSTED ALREADY BUT NO RESPONSE RECIVED
Dear Sir,
I posted this same poet before, but i not get any postive response. i hope now senior Member help me regarding this.
Dear Sir, I am facing this problem with 7610 flashing with Jaf. and tried all old and new version but always showing same error.
plz help me for this.
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51_67PE706420.C2
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51PE706420.34
Languages in ppm: English,B.Mal.,B.Ind. (Apac-3) Chinese (Use MCU C2)
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\Rh-51\RH51_67PE706420.C2
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x10D8
Boot is ready...
Flash ID is 0x22E800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: 37
Loader is ready...
MSID: 84268DDA6F0108F4D0E10897F3
MSID decoded: 3E4EBAF700937E44A8000000
FAID: 2F6BE570AA6421FCFADD8365
Operation took 0 minutes 23 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 029FFFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 2 minutes 52 seconds...
Writing...
Perm. Data Restore OK
Operation took 3 minutes 26 seconds...
Restarting MCU...
Failed! Aborting!
And if i press CHK button then showing following log :
Getting MCU ID
MCU ID: 0x1081
Algo is ready...
i hope i given full detail. this phone was previous problem was white LCD due to that i tried to flash but now showing this problem.
thanks in advance
Old 07-07-2008, 11:02   #2 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
7610 power on solution
try this
wbr
Old 07-07-2008, 12:45   #3 (permalink)
NAVEED74's Avatar
Member: 188574
Sonork: 100.1590742
Thanks Meter: 751
Thanks Brother but ?
Kindly check that phone cannot on with flashing (Box) and battery, both
actually at start there was problem white display, when i want to upgrade software. after that this problem showing. i hope somebody help me for this.
Old 07-07-2008, 13:38   #4 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
full erase and flashing ver 7.0642 then write good pm file .use jaf latest ver :1.98.51 .still same rehot that flash ic slitly after following this .
Old 07-07-2008, 13:45   #5 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
good posting................................
registration complet but no email recive alfred_smd CPF-BOX Ⅱ 3 06-15-2009 06:32
cid 52 sent logs but no response yet... codesxplus Universalbox 22 08-10-2007 19:15
Credit lost whit 6101 and db2020, but no response IVELCO Universalbox 14 07-31-2007 02:44
Page generated in 0.17919 seconds with 10 queries
