6280 video capture ok but when taking photo it freeze!! I have two 6280 video recording is ok no problem but when taking phone the phone freeze and then after too much wait it says fail or can not open image.. I changed flex cable, UI module, Camera module (both), N1060 VCAM 2V8 is normal, CPU and Flash IC changed, RETU changed, RAM changed, Display Changed, Flashed many times.. but no result.. it is still the same.. Please, is there any professional who has any idea about this problem who lived before or solved.. please do not advise amateur advises.. just very professional somethings, because I did manything as above... urgent need help! regards.. |
i have to same problem i flash latest ver file but still same . |
its hardware problem not software change flex cable the problem will be solved |
i know its sound bad bat sometime you change some part who doesnt work so pls tack the main bord and put in work housing and let us know if the problem come from the main bord or from lcd/keypad bord /flex or from main bord flex conector /lcd ic /n1060/camera ic |
I have same problem, i change flat but its still same?;) |
omap processor under upper key board, reball or change :) |
i have the same problem on a 6288, video ok, but photo hang up the phone |
try change the small board of upper keybad |
Change uper keybord. if not ok then change ribon also, Today i sucsess this Quote:
Change uper keybord. if not ok then change ribon also, Today i sucsess this method 100% ok :D |
same problem can u help me |
erase full flash then write latest ver: & write good pm it will be ok . |
Just tell me when you play any video in your ,so its playing well or not? BR |
Re>>>>>>>>>>>>>>>>>> 1 Attachment(s) ....::::MUNAF::::.... |
