6288 charging ok bt not comin on i have nokia 6288 when you change the phone it show the bat bars bt wen you on it still not comin on.i try to flash the phone all ok and show test mode.plz help me |
sir try to change keypad ic....left side connected to power on switch.....tested many times |
first change flex cable then try to reheat the keybad ic tested by me |
here is the solution 1st chek the cable if stell same rebole or change the keypad ic |
bro, 1st, check power switch, 2nd, check flex, 3rd , check keypad ic post your result jimmy |
can you plz show the keypad ic sir? |
2 Attachment(s) Quote:
here is your picture, change front panel key ic |
on off button is not workin.check the on on button then flex cable then keypad ic |
