Old 02-08-2009, 11:05   #1 (permalink)
dil_PAKISTANI's Avatar
Member: 515273
Sonork: 100.1573940
Thanks Meter: 339
Rm-305 nokia 1650 network problem........
Hello forum,
Today I recv a 1650 signal problem,no signals in phone
When I search network manually set to be restart.
Anyone who successfully solve this problem???
Guide me
Thanks
The Following 4 Users Say Thank You to dil_PAKISTANI For This Useful Post:
Old 02-08-2009, 11:18   #2 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
try to change p.f and try
The Following User Says Thank You to ashokassag For This Useful Post:
Old 02-08-2009, 11:28   #3 (permalink)
Member: 757506
Thanks Meter: 14
first of all check software means pm file if problem is same then change pf,ensure 100% allignment of pf .then post result
The Following 2 Users Say Thank You to tadpole For This Useful Post:
Old 02-08-2009, 12:09   #4 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
brother first write pm and then chang rf 100% solution
The Following User Says Thank You to metro2mobile For This Useful Post:
Old 05-16-2009, 08:39   #5 (permalink)
Member: 512578
Thanks Meter: 4
Please Any Have solution .. Please Sheree
The Following User Says Thank You to shahzadje For This Useful Post:
Old 05-16-2009, 08:55   #6 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
yes write pm 100% ok.
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 05-16-2009, 10:02   #7 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br 1. selp test check ufs try it..............
The Following User Says Thank You to biniesh_08 For This Useful Post:
Old 03-09-2010, 11:44   #8 (permalink)
Member: 1066806
Sonork: 10203
Thanks Meter: 18
hi friends i have nokia 1650 Rm 305 i erased fully & flashed fully v.4.51 also read the pm file also fine and randomly the mobile gets resarted i also checked in hwk self test but rf chip installation failed plz give me a proper solution plz plzplz help me thanks in advance [email protected] want 2 change rf ic will it will get cured plz its urgent
The Following User Says Thank You to jnscs For This Useful Post:
Old 03-09-2010, 13:16   #9 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
first erase full flash.then write flash file after write PM file after unlock set.sure 100% solve your problem.
Old 06-03-2010, 14:32   #10 (permalink)
Member: 764263
Sonork: tan002
Thanks Meter: 17
Originally Posted by dil_PAKISTANI View Post
Hello forum,
Guide me
Thanks
Chane the two filters left side on cpu 1000% solved
Old 11-23-2010, 16:46   #11 (permalink)
Member: 531347
Hello forum,
Guide me
Thanks
jaf 1.98.62
1-factory set
2-manual flash
3-warranty
4-unlock
use version 5.71
and then hit flash button.
then work as software ask u.
in the end set will b ok.
in some cases pm have to b write also
Post here all Nokia 1200,1208,1209 and 1650 Network problems mobilecitycbk Nokia Hardware & Hardware Repair 12 09-20-2015 04:01
nokia 1650 network problem sribalaji Nokia Hardware & Hardware Repair 7 02-02-2015 13:06
nokia 1650 network problem chandramouli178 Nokia Hardware & Hardware Repair 26 12-13-2011 04:25
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
rm-305 Nokia 1650 Repair Sim Lock With Mx-key Success ...:::::NP™:::::... MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-09-2010 12:00
Page generated in 0.21651 seconds with 9 queries
