6300 bluetooth hi sir i have a nokia 6300 bluetooth not work plz help sir |
try to write a good pm Crazytel |
6300 bt Frist try to change BT Ghanti If not solved then try to BT ic it is 100% salution:) |
try this solution,,,if solved just push thanks button,,,,,post me result http://www.usaupload.net/d/1n2hgpdciu9 http://www.usaupload.net/del/1n2hgpdciu9/h697803830 |
Thanks good posting.................... |
flash first try to change BT 80%solution |
bro pls just rehot your bt mudule.all well be ok. |
6300 bt problem 1 Attachment(s) hi yes you have reason teepat just rehot your bluetooth module tested by me with many 6300 try this solution good luck:):);) |
Hello Quote:
Try repair Bluetoot first in Jaf. If don't result see hardware. BR Haicha |
bro ur links r not working |
Nokia 6300 bluetooth problem Nokia 6300 bluetooth can be sent but not receive, operation fail, free memory is 3.8mb about. Anybody give me a pic solution. |
